First post, by Zaxxon
i'm trying to run two games,namely Inferno(1995) and Apache longbow (1995).apache is a rip version,inferno is the original floppy version.i tried them with both dosbox and a real 1999-ish pc with a boot disk into DOS.in both of them i get the general fault protection error.i tried them in dosbox and get the same results,with both a default config(for dosbox)and a modified one.on the real 1999 machine,i tried removing the ems line from the boot disk...and inferno now runs,but with no audio,since the soundblaster drivers i use,requires EMS to be enabled,for them to work.what can i do to solve this issue on my real machine and possibly on dosbox as well?
