First post, by Great Hierophant
 - l33t
The Demon's Forge booter works only with tandy machine type and will give 16 color graphics. With cga machine type, the graphics are garbled. The Demon's Forge hard drive conversion will work with cga or tandy machine type, but will only show four color RGB graphics. Unfortunately, this means that the composite color graphics cannot really be viewed with DOSBox. Can the booter be fixed (which should also fix the RGB graphics for what they are worth).
Considering the venetian blinds, I assume this game only supports Tandy, not PCjr.
