Run DosBox twice
First post, by Balderich
Is it possible to run DosBox twice at same time? I need two instances of it.
Reply 2 of 6, by Balderich
I did. But it is not what I need.
I would start two diffrent Instances with diffrent settings.
Instance 1 should listen to COM1 and Instance 2 to COM2.
If I start these 2 instances (2 Copys of DosBox with diffrent setting in the "DOSBox 0.74 Options") only one of them starts... but this starts twice 🙁
So I can run two instances, both listen to COM1 or 2 Instances listen to COM2.
I'd also tried to use one DosBox Installation and as sencond Instance the Portable version, but same issue.
Any Idea?
Reply 3 of 6, by Balderich
Got the issue. Both instances starts the C:\Users\USERNAME\AppData\Local\DOSBox\dosbox-0.74.conf
But how to get rid of it?
Reply 4 of 6, by IIGS_User
-conf
Klimawandel.
Reply 5 of 6, by Balderich
This is what I was looking for. A bit complicated, but finaly it works.
Thanks a lot
Reply 6 of 6, by IIGS_User
Nice to see I was able to help. 😀
Klimawandel.
