First post, by nyirozoli
Hi guys!
I tried to use teemviewer to connect to other computer which was successfully but my problem was when I opened the dosbox on the other computer via teamviewer I could see only a little black box and I could not see dosbox window. Do you have any idea how i could see the program which is run on dosbox via teamviewer?
Thank you guys.
I am waiting you answer, any idea could help me.
Reply 1 of 2, by Jorpho
I think changing the output= line in your DOSBox.conf will probably do the trick.
Alternatively, try running DOSBox from the command line, and typing "set sdl_videodriver=windib" first.
Also, please try to spell "teamviewer" consistently.
Reply 2 of 2, by konc
It's definitely possible, I recently wanted to checkout something and connected with teamviewer. I had in mind that I might not get any image via teamviewer, but to my surprise dosbox and a game was showing correctly.
I have no idea if output setting has to do anything with it but anyway in my config it is set to overlay. Of course as it should be expected games are not playable because of framerate.
