First post, by emendelson
After spending a lot of time building dosbox_logo.h files in order to put a custom icon into DOSBox, I came across a simpler method that doesn't use dosbox_logo.h at all. It seems to work with SVN using Visual C++ on Windows, but possibly I haven't noticed some bad side-effects. The patch is very simple. It adds whatever dosbox.ico you use to the system menu, the Alt-Tab chain, etc. (Not tested on Linux.)
If everyone knows this already, apologies for wasting bandwidth.
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
This only works on windows, while the "old" method works on all OSes DOSBox supports.
Water flows down the stream
Reply 2 of 2, by emendelson
After I posted it, I realized that, even under Windows, it would probably only work under Visual C++, not with any non-Microsoft compiler. Still, it saves a little bit of trouble for people making custom builds, I hope.
