First post, by Great Hierophant
Since having to upgrade to the dreaded Windows 8.1, I discovered that the mouse would become jerky and uncooperative in DOSBox SVNs. When I compiled my SVNs, I used the SDL.DLL created by Virtual C++ 2008. My solution was to use the SDL.DLL from vanilla DOSBox 0.74, problem fixed.
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
Yep, I am aware of that. The wasteland "remake" suffers from the same problem and the SDL.dll fix works there as well.
Water flows down the stream
Reply 2 of 5, by Great Hierophant
When I compiled according to the instructions, I used the 1.2.15 SDL library because I believed that newer=better. However, comparing the file sizes, the 1.2.13 that comes with vanilla 0.74 is larger, and presumably has a greater number of functions or more compatible functionality built-in. I hope Steam has updated their distribution.
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
File size is not an indication of more functions 😉
Qbix is it due to your patch for SDL you used to use? Ddraw/windib order or something like that...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
I don't know what fixes/causes it. I didn't investigate it yet.
