I have no experience with this system and am certainly not an expert but here's my thought on it;
I think you can ignore the 'clock speed' column in the CPU MULTIPLIER SELECTION table. Just take the FSB you're running on and then use the numbers in the column 'multiplier'. Divide by the first number and multiply by the second one.
So for a 66MHz FSB and the first row in that table you'd get 66MHz / 1 x 3 = ~200MHz.
For a 166MHz cpu it's probably using the values in the second row because those match.
The third row would give you a 133MHz cpu and the fourth a 100MHz cpu.
If it doesn't work, try those multipliers with the clock speed stated in the second column. If that does work, then there's a chance the system only works with specific cpu's (150MHz, 133MHz & 90MHz). Unless you had that 166MHz cpu working in the system, in which case I'm out of ideas.
Hope this somewhat helps.
