First post, by borgie83
 - Oldbie
Hi, I'm running dos 7 and would like some advice on gaining more dos memory. I've attached 3 photos of my autoexec.bat, config.sys and also of mem.exe.
I'd greatly appreciate it if someone could look at them and give me any recommendations as to what lines I should add or delete. My sound card seems to be taking a fair chunk out of the memory but my awe32 gives me trouble if I don't load aweutil.
I should also mention that I've tried using himemx and jemm386 to replace himem and emm386 but they seem to take even more memory which doesn't make sense to me. Although I may be doing something wrong when loading these 3rd party memory managers.
An explanation of how to correctly use himemx and jemm386 would also be great as I've tried following the instructions with no luck gaining more precious dos memory.
