First post, by Shodan486
Hello guys. Was looking for a DDR2 for my friend, long lost amongst my junk, and couldn't resist the lure of my socket7 stuff, thus decided to bring something out of it and build it. Well the story was not that much of a success. I just wanted to pick out something I had tested before and worked for me, which was the board in my signature - GA-5AX. Hooked it up with some hardware I know it works with and started it up - The light went on for a second and went off afterwards. No power-up. Disconnected the PSU and attempted once again - no go. Did this with 2 other PSUs - Killed the board 🙁
The board now won't even lit up the status light. And whenever I hook up the PSU to the motherboard, it's giving me a hissing sound - encountered that before on faulty motherboards, thus my presumption of it being dead. Well...It's gonna be really hard to find out what exactly went wrong with it.
So I moved forward and picked up my personal favourite - Iwill XA100 Plus (rev 1.3). VCC VID can be set up higher and there is the soft select for FSB frequency in the bios. On the opposite, the GA-5AX had multiplier selection @ x6 maximum and had 5 PCI slots. The last difference would be in the northbridge, being the latest one on the Iwill and supporting larger cachable amount than the chipset on the gigabyte, earlier revision. Need to verify this info.
The problem I want to elaborate regards both of these mobos - I always want to try very new stuff on very old stuff 😁 - particularly meaning that I want to run my newly acquired 3D Prophet 9800 on these mobos. I can't get enough pain and try these things - TNT2 on 486 = never worked and ATI cards on Abit VP6 (via apollo pro) - no fastwrites etc.
In this case, I am facing stability issues - 6.2 ati driver no go as well as the original 3D prophet 797 version. 3D accelerated stuff gets hung up after couple of seconds, requiring me to cold-reboot. Got the AGP Ali driver - tried the opposite settings and also of all values - no help. AGP 1x was resolved by forcing the 2X value in the registry. Forcing the SBAoff did no help. The psu is 350W, pretty much powerful. I know I was able to run a FX5700LE stable with no glitches and I even managed to run GunMetal, which is a DX9 mech game. But with the Ati cards it ain't that successful.
Any ideas?
MOBO: PVI-486SP3 Rev 1.2
CPU: POD-83
RAM: 2x16MB
VIDEO: Matrox Millenium 2MB/Voodoo2 12MB/Video Blaster VT300
AUDIO: SB Vibra16 FM
SCSI: 72GB 15k RPM HDD/YAMAHA CD-RW 16x/ZIP drive + FDD drive
NIC: 3Com Etherlink III
PSU: 230W Generic
OS: Win95 OSR2.5
