First post, by guest
https://sourceforge.net/tracker/index.php?fun … 580&atid=112580
See this bug report for Bochs, you've got the exact same problem. It can explain a lot of app hangs when this doesn't work...
As a reference point on the importance of this, Microsoft gets it right in the NT/W2K DOS emulation, and so does IBM in OS/2's DOS boxes.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
I thought we had this counter.
I actually am pretty sure we got this counter.
Civilisation 1 needed it.
Maybe there's an other one. 😀
Water flows down the stream
