Best setup for running demanding DOS SVGA games
First post, by mr_bigmouth_502
I'm aware that this has probably been discussed to death, but if I were to build a system specifically for playing demanding DOS SVGA games, at 640x480 or higher resolutions, what sort of specs would you recommend? I'm mainly looking to run stuff like:
- Carmageddon/Splat Pack
- Dungeon Keeper
- Descent II
- Duke Nukem 3D/other Build engine games
- pretty much any other games that run under DOS and can take advantage of SVGA graphics
The main thing I'm wondering is, is it worth looking into an exotic Pentium 4/AMD K7-based board with ISA slots, or will a much more common Pentium III board with ISA slots do the trick? As well, are ISA slots even necessary for decent DOS sound support, or can I get away with using a PCI sound card and running these games under Windows? Lastly, besides the games I mentioned, are there even any other notable DOS SVGA games with high resource demands?
Reply 1 of 79, by Mau1wurf1977
Not sure about Dungeon Keeper, is this a newer DOS game?
I can tell you that having an ISA cards for late DOS games isn't needed. The drivers that these games use work extremely well with PCI sound cards.
What sound card do I recommend? Any card with the Vortex 2 chip. Even has a wavetable header.
For S-VGA you can't have enough performance. An Intel chipset based Tualatin build should work well. Slot 1 might be ok, but might run out of steam at higher resolutions.
Pentium 4 is even faster but I haven't tried the Vortex 2 on such a machine, it might now work.
Make sure you load these tools that speed up graphics performance. There is one included in the VGA benchmark project.
My YouTube channel
Reply 2 of 79, by Jolaes76
EF 2000, F22 Lightning II, Screamer 2, Screamer Rally come to mind - but there are other 1995-96 SVGA flight/space sims out there which are not 3dfx exclusive.
and yes, the power of an A64 or P4 processor is showing when everything is maxed out 😀
You can usually get away with Windows 9x and PCI sound cards, in most cases the speed drop is not radical compared to pure DOS.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 3 of 79, by F2bnp
I don't think going P4 is a good idea. Generally speaking, a P3 1GHz is more than good enough for most of those games. A 1.4GHz Tualatin is even better.
I guess you could go the Athlon way, a lot of people have talked about the Athlon XP-M and how it can scale thanks to its unlocked multiplier from 600MHz all the way to 2GHz+.
I can't think of any DOS game even at 1024x768 that would be slow on a Tualatin 1.4 though... I guess Mechwarrior 2 might have some slowdowns on the P3 1GHz.
Reply 4 of 79, by Darkman
you will do much better with a PIII board with ISA , very few DOS games , including the later SVGA ones will have any issues on it, with the exception of some having speed issues due to CPU sensitivity, but that will affect a P4 even more so.
to put things into perspective, my 700Mhz Coppermine machine runs Duke Nukem 3D at 800X600 smoothly , as it does every other SVGA game I throw at it. heck it will even run DOS Quake at 800X600 decently (though at 1024X768 it does lag quite a bit).
so like others have said a 1Ghz or Tualatin will have no trouble at all.
ISA isn't a must but its obviously much better than having to try and get a PCI card to run in DOS (especially some of the very late Win9X era cards like the Live) , not to mention the flexability and option to run a card that isn't a Sound Blaster 16. quite a few of the later gamest support the Gravis Ultrasound or an AWE32/64 .
of course you could run two sound cards as well.
Reply 6 of 79, by senrew
do eeeeeet
Halcyon: PC Chips M525, P100, 64MB, Millenium 1, Voodoo1, AWE64, DVD, Win95B
Reply 7 of 79, by Jorpho
Even if you don't want to use DOSBox for some reason, there are Windows ports of Dungeon Keeper, Descent II, and Duke Nukem 3D.
Redguard and Battlespire are often cited as the most demanding DOS games.
Except you probably won't get a PCI sound card working in DOS on a Pentium 4 motherboard.
Reply 8 of 79, by mr_bigmouth_502
Jorpho wrote:
Even if you don't want to use DOSBox for some reason, there are Windows ports of Dungeon Keeper, Descent II, and Duke Nukem 3D. […]
I'm doing this specifically BECAUSE I started playing Dungeon Keeper and Descent II in DosBox, and after seeing how awesome they look in high-res, I want to see what it'll take to play them at the same resolutions on actual hardware. 😉
Reply 10 of 79, by leileilol
SB PCI 128 works on mine, terrible sounding "FM" and all.
FUCK "AI"
Reply 11 of 79, by mr_bigmouth_502
With PCI soundcard compatibility in DOS, I think it just varies from chipset to chipset, though running DOS games through Win9x certainly seems to help, at least from my experience.
Reply 13 of 79, by Jorpho
Interesting. What's the board?
Reply 14 of 79, by Mau1wurf1977
Ok so I tried the Vortex 2 card in a S478 board (Intel chipset) and the driver complains:
Your Vortex adaoter is not plugged into the primary PCI bus. The MPU401, joystick, modem and Sound Blaster capabilities may not work when on the secondary PCI bus.
Is this the issue?
My YouTube channel
Reply 15 of 79, by Mau1wurf1977
Update:
Ok so the Vortex 2 issue seems to be a driver bug with the SuperQuad card. The Turtle Beach card works fine.
For some reason the Voodoo doesn't seem to work, but likely also a driver issue. When launching GLQuake I get some checkboard pattern in green colour. The Voodoo also doesn't show up via DXdiag.exe.
Good news however regarding Sound Blaster Pro compatibility.
Confirmed working on this motherboard: http://www.asrock.com/mb/intel/p4i65g/
So this means it will work on a TON of P4 boards.
Tested with Quake Shareware version from within Windows.
My YouTube channel
Reply 16 of 79, by NitroX infinity
Have you tried the Voodoo in a different PCI slot? Could be IRQ problems.
Reply 17 of 79, by Mau1wurf1977
Yea tried all that. They get detected by the driver, install fine, show up in device manager, but can't be used by games.
Could be anything, I installed quite a few drivers, so will play with this another day.
But the good news is:
Vortex 2 Sound Blaster Pro works in DOS on a Intel 865 chipset Pentium 4 board 😀
My YouTube channel
Reply 18 of 79, by Jorpho
It is good to know that a Pentium 4 motherboard does not necessarily lack PCI soundcard capability, but last time this came up it was suggested that a particular chipset alone is not necessarily an indication of compatibility.
PCI sound cards and Chipsets from various manufacturers...
I really wish this sort of thing wasn't so shrouded in mystery.
Reply 19 of 79, by soviet conscript
wow....Pentium III and 4? my "fast" DOS machine is a 200mhz mmx Pentium with a awe32 and a PCI s3 trio 64v2/GX and it plays games like Duke3d maxed silky smooth. had no idea you needed that much power for some of those titles.
