First post, by soviet conscript
been trying to upgrade the video on my Macintosh 7600 w/ g3 CPU upgrade and system 8.6 and I have some issues
recently randomly came across and picked up a voodoo 5500 mac edition card and on installing it in my 7600 and running the drivers the card work, but with one issue. it seems to be in some kind of duel monitor mode. the image I seem to get from the voodoo is to the far right of the screen. I can tell because if I run my mouse to the left it eventually enters the screen. also I can barely see the edges of my desktop icons on the left corner. If I switch back to the on board video I get my desktop. why is this happening and how do I make the voodoo the primary video device?
second question is I'm thinking of just going for a Radeon 7000 / voodoo 2 setup instead of the v5 but there seems to be issues installing the Radeon 7000 in system 8.6. I see a lot of references online about how people have gotten the card installed in 8.6 with some fiddling around with the installer but no one describes HOW this was specifically done. I'm not a mac person at all so I was hoping someone would be able to outline thew procedure.
Reply 2 of 5, by soviet conscript
collector wrote:
This forum is for Mac Emulation. Ask old hardware questions in Marvin.
sorry. its not made real clear. "mac hardware" is mentioned in the subtitle and scrolling through the topics a few seemed to having nothing to do with emulation. such as "best OS9 and earlier exclusive games" and so forth, not really an emulation specific topic. Add to the fact that theres pretty much no talk of anything mac in the marvin forum and it can make where to post such questions a little foggy.
can a mod please move this then?
Reply 3 of 5, by obobskivich
Lemme qualify: I'm not a Mac person either.
I don't think the Voodoo5 supports dual-monitor; if I remember right the DVI output on the Mac cards is an "either/or" proposition with the VGA connector. Have you tried connecting to the other output from the one you're on? Do you have another machine to test the card in (or can you otherwise confirm the card itself is properly working)?
As far as the Mac goes - the last time I used an older Apple system I know there was some sort of "system properties" that was fairly easily accessed that let you setup things like display resolution and outputs (on OS X it is called "Displays" under System Preferences; on OS 8 you should find it in "Control Panels" under System Folder) - anything in there showing multiple monitor outputs running? Or that lets you adjust which is primary?
Reply 4 of 5, by soviet conscript
I only have one machine I can try it in. I'm almost positive the card works fine because its function just fine only as a second monitor output (seemingly)that's actually a good I idea I didn't try about the 2 outputs on the card. I only tried the vga port not the DVI post. I mean I just assumed they were the same and that the vga was primary. I'll open it up later and try outputting from the dvi port. I just hate the cases on these old macs. the plastic is so brittle by now and there virtually all plastic with plastic tabs and what not. I think every time I open up one of these things or put it back together another little plastic tab gets snapped off somewhere.
does anyone know if the Radeon 7000 is more powerful then a v 5500? even PC wise.
Reply 5 of 5, by RacoonRider
I think your problem will vanish once you find a way to disable primary video card.
