First post, by theelf
Hi!!
Any idea if is possible to control cycles inside dosbox? I mean, from a batch file for example
I made a very good configuration, with a fixed cycles of 6000, and most games run well, but some of them, need at least 19000 to be fluid
For example, Black Stone. For this game if i can do a batch file like this
cycles=19000
bstone
cycles=6000
it will be perfect..... use more cycles for the game, and came back to normal after play..
any ideas?
Thanks
Reply 2 of 3, by theelf
yes, i tried all combinations, no luck, cycles never change
Thanks
EDIT: Ok, when you say "did you try it ?" I was thinking like "mm... i cant be so idiot.. 😊 " and i tried again, but I was right not luck...
Then i downloaded official dosbox, and "cycles=" works......... 😵
The problem is that i have the PC connected to a CRT at 15khz, and because of this I use a custom build, to fix all output to NTSC
And, in the build I use, the command dont work, if I write "cycles=" nothing happen
Is my fault, since in official dosbox works, i need to check what happen in the custom build
Just because i always use the custom version, I did not realize of this
Thanks again, sorry
Reply 3 of 3, by VileR
What is this custom NTSC build? are the patch & binary available?
Also, alternative approaches which may or may not work in that build:
cycles 19000 (without the "=")
cycles fixed 19000
config -set cycles=fixed 19000
