Reply 1 of 23, by subhuman@xgtx
- Oldbie
wrote:What is the performance difference between Stingray 128/3D and Diamond Monster 3D (with S3 Virge GX)?
I want to use it in an Socket 5 Pentium 133MHz computer.
I have a Jazz Mutimedia Rush card and I would say it is 5-7 fps slower than a voodoo1 on Glquake
Reply 2 of 23, by Stojke
Reply 3 of 23, by NitroX infinity
- Member
According to most sources, the Voodoo Rush performed about 10% slower than a Voodoo Graphics. To resolve this companies clocked the Voodoo Rush 10% higher. Don't know if they all did it though.
Reply 4 of 23, by subhuman@xgtx
- Oldbie
wrote:What are Voodoo 1 results?
I am interested into percentage, since i have only two PCI slots. Freeing one up opens more room for expansions.
31-32 fps. Glquake 0.97; SST_GRXCLK=50; set SST_SWAP_EN_WAIT_ON_VSYNC=1
I don't think all dos glide titles are compatible with Rush either.
Reply 5 of 23, by Stojke
Reply 6 of 23, by sliderider
- l33t++
wrote:According to most sources, the Voodoo Rush performed about 10% slower than a Voodoo Graphics. To resolve this companies clocked the Voodoo Rush 10% higher. Don't know if they all did it though.
AFAIK, Hercules was the only one that boosted the clocks. They also added a little more RAM over the reference design. That's why the Hercules Rush cards generally get higher prices than the rest.
Reply 7 of 23, by Putas
- Oldbie
wrote:wrote:According to most sources, the Voodoo Rush performed about 10% slower than a Voodoo Graphics. To resolve this companies clocked the Voodoo Rush 10% higher. Don't know if they all did it though.
AFAIK, this comes from first Hercules Rush card being 45 MHz. Later they used 50 just like anybody else, so equal to Voodoo Graphics. I measured the Rush was 20% slower on average.
Reply 8 of 23, by Stojke
Reply 9 of 23, by NitroX infinity
- Member
Quake & Quake 2 (timedemos), 3DMark 2001se.
Reply 10 of 23, by Stojke
- l33t
Since timedemo doesnt display FPS information here is Player Bench and Super Scape:
CPU: Intel Pentium 1 133MHz (socket 5)
RAM: 128MB EDO 70ns
Diamond Monster 3D 4MB + S3 Virge GX 2MB
Player Bench: 16.1 FPS
Super Scape: 108.6 FPS
Hercules Stingray 128/3D 8MB
Super Scape: 108.8 FPS
Stingray performance is almost exactly the same as Diamond Monster 3D + S3 Virge GX. Where it has 0.2FPS more in Super Scape.
Reply 11 of 23, by Putas
- Oldbie
So Virge GX and AT25 are probably CPU limited.
Reply 12 of 23, by Stojke
Reply 13 of 23, by sliderider
- l33t++
Now that is unexpected. Everyone always says that Rush is slower than Voodoo 1 but this test shows that it is almost exactly the same with that CPU. I wonder at what point they begin to diverge.
Reply 14 of 23, by Stojke
- l33t
Reply 15 of 23, by Stojke
- l33t
Here are some more results from Super Scape and Player Bench.
AMD K6-II 400MHz
PlayerBench 30.3 FPS
SuperScape 184.6 FPS
Diamond Monster 3D + S3 Virge GX 2MB
PlayerBench 30.4 FPS
SuperScape 184.1 FPS
Dell Optiplex GX1 Pentium 3 700MHz
PlayerBench / (doesn't work at all, i blame Dell)
SuperScape 360.9 FPS
PlayerBench 39.9 FPS
SuperScape 360.6 FPS
I will try Quake newer version on AMD K6 and i will try all the rest on IBM 233+ .
[E]
AMD 5x86 133MHz , 4MB FPM memory, 256kB L2
PlayerBench 7.1 FPS
SuperScape 74.6 FPS
PlayerBench 7.5 FPS
SuperScape 76.6 FPS
Reply 16 of 23, by Putas
- Oldbie
Superscape is not 3d accelerated. What was the PlayerBench setting?
Reply 17 of 23, by Stojke
Reply 18 of 23, by Putas
- Oldbie
As I suspected, you are not testing the Voodoos at all.
