OK...this is annoying....hmmm
First post, by borgie83
As the title suggests...I'm quite annoyed! Why you ask?
Maybe it's because my BFG Geforce 4 TI4600, with its beautiful blue PCB, arrived from overseas only to be out of action. No, this was not the sellers fault as he sold me an item that was tested and working fine. Made sure of that before the purchase.
This, my fellow vogoners is due to the ram getting ripped straight off the pcb with minimal force. You see, attached were some aluminium thermaltake heatsinks which I needed to replace. The first three heatsinks came off fine but when it came to the last one...oops!! Bloody hell!
Anyone have any recommendations as this is a first for me and judging from all the super tiny pins I'm not up to the task of repairing this 🙁 I wouldn't even know where to buy new ram for this. I'd really like to repair it though as I have already tried and can't find another blue pcb TI4600 anywhere.
Here's a photo:
Reply 1 of 27, by d1stortion
Your wording suggests this is some kind of design flaw or something. Glued RAM heatsinks generally aren't meant to be pulled at...
Unless you can find someone with skills and tools for BGA soldering I don't see how you could repair that card.
Reply 2 of 27, by borgie83
I'm not sure if it was a design flaw but I definitely was not suggesting that. Was just strange how it just popped straight off. I've removed dozens of heatsinks before and know not to apply much force but this has never happened to me before.
Reply 3 of 27, by d1stortion
Maybe should have used a flat head screwdriver? At least this seems to be the suggested way for VSA-100 heatsinks.
Reply 4 of 27, by keropi
Since the BGA pads are damaged I believe this card is as good as a paperweight now...
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 5 of 27, by Stojke
Unless you can some how fix those lines leading to the pad, say bye bye.
Reply 6 of 27, by Auzner
Let me put it this way, unless this was an important component for an aerospace computer that only 100 were made, there's no way to repair this from what I see in that photo.
You have 144 pins, with various pads ripped off the IC or the PCB. Then the PCB has most of its traces ripped up. You could try a micro drill press to get back to each of the pads and PCB traces and then deadbug solder it. Which would probably add too much capacitance and mismatched path delays that would make the memory very unreliable.
A Ti 4600 didn't even need ram sinks. Next time use a heatgun to melt the adhesive. If the BGA chip comes up with it at least everything is still intact.
Reply 8 of 27, by GeorgeMan
Are these ram chips (or equivalents) nowhere to be found? Can't somebody just buy one?
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 9 of 27, by keropi
The ram chips are not the problem, the problem is the damaged BGA pads
Reply 10 of 27, by GeorgeMan
Oh it seems that the chip attacted my attention and I didn't see the pcb, which is in pretty bad shape... 😒
Reply 11 of 27, by RacoonRider
If I were you, I'd be half a head balder. There's nothing you can do, just glue the chip back in place and put it on display... as a reminder that one should leave well enough alone.
Reply 12 of 27, by borgie83
Ok judging from all the replies I'm going to take the slap in the face, bin it and move on. In the back of my mind I had a strong feeling it was done for. Was just hoping someone had any ideas regarding repairing it. It cost me around $45 so it's not a massive loss but a loss none the less unfortunately.
I'd buy another one but the BFG TI4600 is quite rare and I haven't seen one for sale anywhere.
Thanks anyway guys 😀
Reply 13 of 27, by gandhig
A very very long and probably worthless shot, but is there a chance to run it with the reduced RAM (i.e if only the RAM got ripped off and nothing else is damaged)?
Nvidia partners slapping different amount of RAM for a particular GPU, there being no separate video bios or driver for each such variant, would it be possible to hack/program the memory controller to accept the reduction in memory?
Edit: AFAIK, the video bios is only used during initial boot and the driver completely takes over after the OS loads. I guess the video bios routines are used only by the DOS games. Earlier I used to run my system with the discrete GT520 GPU but with onboard SIS305 video bios loaded by the system BIOS. I didn't notice any problem in Windows as both are IBM compatible VGA bioses.
Dosbox SVN r4019 + savestates Build (Alpha)
1st thread & the only one related to the forum(?)...warning about modern-retro combo
Dead, but, Personal Favourite
Replacement for Candy Crush...Train the Brain
Reply 14 of 27, by konc
I don't have any clue whether this is even possible or not, but it's a great idea/possibility that I never thought of. Just felt like mentioning it 😀
Reply 15 of 27, by Stojke
if it tries to load something into that ram part it will crash. Plus it is possible that it isnt the last bank, but in the middle.
Reply 16 of 27, by Auzner
http://pdf.datasheetcatalog.com/datasheets2/31/310470_1.pdf
7 chips of 1M x 32bit x 4 bank = 112MB. The addressing will very likely not work like that. The 128-bit width could be needed from 4 chips, or maybe from the 4 banks. If you removed 3 more of the correct chips it would be funny to see that work.
Reply 17 of 27, by gandhig
I suppose it is because OP's first intention was to get it repaired to its original state for which I had nothing to add. Once he decided that it may not be possible, I felt to chip in with a far-fetching alternative i.e. if he doesn't feel bad about his beloved card's usage on a sub-optimal condition.
However as other posters have mentioned, I also felt that it might not be viable at all. It was just a thought really. BTW, I'm flattered by your comment.
Reply 18 of 27, by obobskivich
And this is why we don't remove BGA ramsinks on any card - generally speaking if they're installed by the manufacturer, they're sufficient for the card and/or there for a reason. Cards that use "all in one" cooling solutions (like the FX 5800 Ultra) can have sinks added if you're changing the cooler, but I wouldn't suggest doing it with permanent adhesive.
There's no hope for this card; recycle it and move on. As far as running it without the chip - I'd be surprised if it didn't release magical smoke when powered up - you've got hundreds of open (or worse, potentially shorted) contacts that aren't being dealt with or terminated. Save the heatsink if you can, but otherwise move on. I am sorry to see the card damaged, and sorry to hear about your experience here - always sucks when a device bites it.
As far as another colored PCB GeForce 4 Ti, I know that PNY tended to vacillate between purple and blue back then (there are both colored versions of GeForce FX for example), and Chaintech often used blue PCBs when they were still in business. You might also find a purple PNY or AOpen, and there's also Gainward and their glorious red cards (these two suggestions are mostly if you just wanted something different from the plain-jane green, but not necessarily blue).
Reply 19 of 27, by borgie83
The heatsinks wernt manufacturer heatsinks but aftermarket thermaltake heatsinks. I wanted to remove them because for one, they were ugly and two because I wanted to replace them with copper heatsinks as opposed to aluminium heatsinks.
Regarding trying it in the computer in its current state...I wouldn't dare and you can almost guarantee there would be issues with it anyway.
I have looked at the PNY and Chaintech cards and have noticed several blue and purple ones for sale. Can't find any TI4600's in blue though unfortunately. May have to settle with a TI4200.
