First post, by Cut Man
Is it possible to have DOSBox boot from an actual physical HDD, not an image file?
I want to access the HDD's operating system and files just like I would normally.
Unless I missed it in the documentation, I can find no way to do this.
Thank you.
Reply 2 of 3, by leileilol
Especially considering file systems and all that
Reply 3 of 3, by ripa
On Linux, try imgmounting the physical hard drive device node. Something like this in Dosbox:
imgmount 2 /dev/sdb -size 512,63,16,142 -fs none
boot -l C
Make sure you use the correct device node and don't come crying if your hard drive contents become corrupt.
