First post, by skitters
How do I create separate configurations for different DOS games with DOSBox on a Mac?
The DOSBox 0.74 manual says:
An extra configuration file can be generated by CONFIG.COM, which can be found on the internal DOSBox Z: drive when you start up DOSBox. Look in the Section 4: "Internal programs" for usage of CONFIG.COM. You can start DOSBox with the -conf switch to load the generated file and use its settings.
DOSBox will load configuration files that are specified with -conf. If none were specified, it will try to load "dosbox.conf" from the local directory. If there is none, DOSBox will load the user configuration file. This file will be created if it doesn't exist.
So does this mean you'd say something like this to start a game?
C:\SIERRA>brain.bat -/Users/username/Documents/DOSgames/C/Sierra/Brain/dosbox.conf
or would it be more like
C:\SIERRA>brain.bat -conf /Users/username/Documents/DOSgames/C/Sierra/Brain/dosbox.conf
or would it be enough to just dump the config in the Brain folder and say
...and DOSBox would automatically look for the dosbox.conf in the game folder C because it saw "-conf" after the brain.bat that was used to start the game?
Or do you use the CONFIG command to tell DOSBox to create a game-specific name for the conf file other than dosbox.conf (maybe brain.conf in this example), and end up with
C:\SIERRA>brain.bat -/Users/username/Documents/DOSgames/C/Sierra/Brain/brain.conf
or something else?
I'm not sure if it's clear here, but Dr. Brain installed in C:\Sierra\Brain but put brain.conf in the C:\Sierra folder and not the C:\Sierra\Brain folder.
Reply 1 of 14, by VileR
You want to start DOSBox (not the game) with the -conf switch.
Reply 4 of 14, by skitters
When I make an alias, right-click, and "Get Info" it says
DOSBox.app alias
in the Name & Extension box.
I assume I'm supposed to change the box to
DOSBox.app -conf
But am I also supposed to put the location of the dosbox.conf after that as
DOSBox.app -conf /Users/username/Documents/DOSgames/C/Sierra/Brain/dosbox.conf
or do something else?
Reply 6 of 14, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
That works differently with the app bundle, something with -args or so. If you use dosbox.app/contents/macos/dosbox you can directly pass arguments, though
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 14, by skitters
OK I'll try that then. Thanks.
EDIT.........
Not working. It's still using the ~/Library/Preferences/DOSBox 0.74 Preferences file and not the dosbox.conf I put inside the BRAIN folder.
This is what I typed inside the "Name & Extension" box, which is the only place I see in the Get Info for the alias where you can type anything in
DOSBox.app/contents/macos/dosbox -conf /Users/username/Documents/DOSgames/C/Sierra/Brain/dosbox.conf
Reply 9 of 14, by skitters
collector wrote:
I will assume that you did not overlook replacing the "username" in the path with your real profile name.
Good idea 😀 But it's not the problem.
Am I supposed to make an alias some other way besides right-clicking DOSBox.app in the Applications folder and choosing "Make Alias?"
Reply 10 of 14, by Dominus
DOSBox Moderator
No, you can't do that as alias. You use the commands in terminal.app.
If you want a standalone clickable thing for each game it's more difficult. Afaik there is a Dosbox wrapper for this somewhere in the forum
Reply 11 of 14, by skitters
OK, it works from terminal. I guess I could create a .bat file if this was Windows, but it's a Mac.
Maybe something like this would work
https://discussions.apple.com/thread/2778315
Reply 14 of 14, by skitters
Dominus wrote:
Look at dosbox' wiki, I wrote an apple script to choose between several configs
I guess this is your script then
http://www.dosbox.com/wiki/Mac_OSX_Advanced
I'll try working with that.
Thank you very much for your help, Dominus.
You too, Collector.
