AWE32 SPDIF OPL3
First post, by Stojke
Yo yo, after quite some time i managed to obtain an CT2760 sound card.
As i wrote here before - OPL recording problem , i managed to record using analogue sound via Turtle Beach Pinnacle (which records a very clean sound).
Now i would like to try digital recording using CT2760 SPDIF and Asus Xonar D2X SPDIF.
Is it possible to output SPDIF in MS DOS? I find installing windows 95 again a burden 😒
Reply 1 of 8, by tyuper
AWE32/64 doesn't need any OS-dependent driver to produce SPDIF data from OPL3/CQM. 😀
Reply 2 of 8, by Stojke
So at all times digital audio is transmitted via SPDIF?
Reply 3 of 8, by tyuper
Yes.
Reply 4 of 8, by Stojke
Thanks 😁
Can you tell me what is the SPDIF frequency? (If i remember correctly, it should be set to same kHz on both ends)
Reply 5 of 8, by tyuper
Just plain 44,1 KHz @ 16 bit. 😀
Reply 6 of 8, by Stojke
Awesome! Thank you very much.
For your help, here is Metallica - Master of Puppets by Viper , OPL3 😈
[ OGG - Download ]
Reply 7 of 8, by tyuper
Heh, no problem Stojke! Metallica sounds great in OPL3 rendition \m/ 😁
Can I know, what program you used to play this?
Reply 8 of 8, by Stojke
Of course Note! 😀)
Note FM Tracker
have fun!
