First post, by Holering
Curious who here is running a 440FX intel system. This chip was released in 1996 but supported the Pentium 2 and nobody talks much about it. Yes I know there's the almighty 440BX, and the better 440LX and EX chips, but those are much newer and support Pentium III.
440FX also seems to run up to, a celeron 533 (non "a" without sse), so it should be pretty bloody fast. How high can the FSB go anyway? What about the multiplier (how bout' Pentium 2 333 mhz with 5.5 multiplier)? Pics would be great of course.
Would be interesting to compare framerates to SDRAM based 440LX with same CPU and FSB clock.
Reply 1 of 6, by GL1zdA
Many 440FX motherboards support only 2.8V CPUs, so you're limited to Pentium II Klamath with them. FSB is 66 MHz.
Here's a benchmark with 440FX and 440LX boards:
http://www.tomshardware.com/reviews/review-pe … ntel,39-10.html
getquake.gif | InfoWorld/PC Magazine Indices
Reply 2 of 6, by mwdmeyer
I have a 440FX system, although it is a dual Pentium Pro (actually it is a Pentium II Overdrive now) 😁
Dual Pentium Pro Computer
Reply 3 of 6, by Holering
That is a very good system mwdmeyer. Seriously, how could you not be impressed back in the day with a 1996 chipset, even comparing single P2 overdrive to k6III+. Pentium II should run DOS games much better than Pentium Pro (improved segment register caches). Who needs agp when you got: Rage 128, Riva TNT, Geforce DDR, and Voodoo 1-5 on PCI. Wonder how zsnes runs on your machine.
Reply 4 of 6, by vetz
I also have a 440FX system I'm going to start to put together (will put up a build log)
ASUS P65UP5 + C-P6ND
http://www.tomshardware.com/reviews/review-so … oards,48-4.html
This board also supports Dual Socket 7 (430HX) and Dual Slot 1 if you have the correct CPU board.
Reply 5 of 6, by Standard Def Steve
I have an old Compaq Deskpro 4000 system based on the 440FX.
The Compaq Cardboardpro 4000
It's from early '97, but I'll rattle off the specs anyway.
-PII-300
-192MB EDO (6x32MB). Board will take up to 384, but I just don't feel the need to max this out. I'm completely unimpressed by the chipset's memory performance.
-PCI Radeon 7000 (64MB DDR with a DVI port that surprisingly supports 1920x1200--my 9800Pro certainly doesn't)
-SB AWE64
-20GB/7200 Maxtor PATA HDD--one of the only drives I have that will actually run in DMA mode on this computer.
-LG CD-RW/DVD-ROM
-No onboard USB, so I use a PCI USB card
-No form of power management or soft-off. Has a mechanically controlled PSU with AT leads as well as a strange 10-pin aux connector, which I read was to supply power to the CPU. It's a strange configuration for this type of computer, as many of the P-MMX Deskpro 4000s of the time had ATX PSUs (and even USB).
-Has onboard ethernet, but it appears to be limited to 10mb/s, so I use a PCI 10/100 card.
-The board does support 2.0v operation, but unfortunately it doesn't recognize the L2 cache of Deschutes, Mendocino, and Katmai processors. CPU-Z even classifies these processors as Convington! Therefore, Klamath-300 is the fastest CPU it will properly run.
-Running DOS 6.22 and Windows 2000.
I'm not a big fan of the 440FX chipset. It may have been OK for single-socket PPro systems, but it really seems to be a bottleneck for PII processors. Memory performance is terrible, and the system feels slower than similarly configured LX/BX systems. With the same video card, a PII-350/440BX system scores over twice as high in 3DMark01.
"A little sign-in here, a touch of WiFi there..."
Reply 6 of 6, by Holering
Really? That's very interesting. Came to believe only memory bandwidth would show improvement on LX/BX chips. Perhaps there's other improvements with LX/BX? Why is Intel always so expensive anyway (they weren't so bad during pentium 3 to core2 days)?
