First post, by PearlChoco
I'm considering buying a new tablet, but I'm still not decided which one. dosbox compatibility might be the deciding factor.
Does dosbox support the MS Surface Pro 2 stylus? I know the samsung S-pen can be used as a mouse, but i haven't read anything about the Surface.
Thanks!
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Dosbox has problems with tablets since it uses SDL 1.2x which is bad with tablets and similar inputs.
There is an experimental port to SDL 2 which should/might be better but I can't test.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by PearlChoco
Ok, so I can better stick to Samsung tablets.
Thanks.
Reply 4 of 5, by PearlChoco
I've been playing some ScummVM games on my Galaxy Note II with the S-Pen, and that works really flawlessly; equally as good as with a mouse!
Reply 5 of 5, by Dominus
DOSBox Moderator
Yeah, kind of not the same thing but it might be ok...
I'm just giving you a warning that it might not work as expected...
