Sorry about the long time for a reply (very very busy with work
stuff) and thank you for the feedback.
You will get a click/pop every time there is a buffer underrun. You
might also have noticed that the latency increases if there are a
lot of underruns. If you use it, mt32d/xmt32, with Dosbox then a
PIII 600Mhz computer will not keep up since Dosbox is a real CPU
monster. I with my old PIII 550Mhz I could get very few underruns
if I turned reverb down and just tried playing midi files with a simple
midi player like pmidi.
SSE support is a bit clicky in the last version so it is switched
off by default since I have been very busy so it is a low priority fix.
3DNow support has never been tested since I don't have an AMD
computer to test with.
A few instruments (like the harpsicord) clip (click) at maximum volume.
I am not sure if this is a problem unique to the Linux version and I
do not currently have a suitable windows computer to test the original
version with. I will take a closer look at this issue when I can.
Thanks again
