First post, by ibm5155
So, Hi guys, I was making my arcade machine, but one day, I discovered that I was missing one of my coolest DOS game 😳, Tomb Raider 1!!!...
So I installed the GOG version, but, the installer didn't liiked windows 98 :s, so I installed it into another computer and I got the iso from TR1,...
Ok it installed well, and the the sound setup, oh, somehow, the sb 16 config wasn't working, I lost some time to know that it was working with the rest of the sound blaster configurations on it >.>...
Ok then I started tr1 and bam, no music and no 3DFX >.>...
I discovered that on that cd there were two patches, one called 3DFX and another called VOODOO, I tried first the 3DFX, but, there was no 3DFX logo and it was running in software mode 😠 , So, I tried the VOODOO one, and when I tried to run it, my computer reseted 😮...
So I tried to install that path from glidos where it replace some files like tomb.exe and add tombud.exe, also, the weird part, is that tombud actually works, but there's no 3DFX logo 😖...
Also, I'm trying to run it from a iso file, and even the music file is not played '-'...
Idk why tombraiderud is working but not tomb.exe, is there something that I'm missing? (plus, The folder has the glide2x.ovl and dll from voodoo3 10000 driver)
Reply 1 of 4, by Holering
Sounds like a possible IRQ conflict. Check device manager for IRQ conflicts, or shared irqs; and try to disable whatever it is that's sharing IRqs (or try to change its irq if you need it. Try changing PCI cards to different slots if irqs still don't change).
If that doesn't work, run memtest to check for faulty ram. Could also be faulty power supply. If that's all fine then maybe Tomb Raider isn't finding enough memory (this can be very common on newer systems with lots of ram).
Reply 2 of 4, by vetz
3DFX.exe is the Voodoo Graphics patch and Voodoo.exe is the Voodoo Rush patch. Only the Voodoo Rush patch works on Voodoo3, but it is recommended to play it in a DOS window under Windows98 to avoid the inventory crash. You machine should not freeze like that anyway, sounds like another problem tbh, not related to the graphics card.
Reply 3 of 4, by ibm5155
Here's the system:
Intel Pentium MMX233MHz 1mb cache l2
128mb sdram
250WATTS psu fortek (for now the only game with problems is tr1, others like tr3, coolin mcrae rally works fine)
Guillemot Maxi sound Game Theater 64 (isa)
NEC usb 2.0 port (pci)
Ethernet pci
Voodoo 3 3000 agp
Via usb onboard
MS-5184 Motherboard (1.1 update bios)
DMA
0,5,6,7:free
1,3:sound card
2:floppy disc controller
4:DMA controller
IRQ:
0:System timer
1:101/102 keyboard
2:interrupt controller
3,4:free
5:sound card
6:floppy disk controller
7:irq port to PCI
7:NEC PCI to USB
8:CMOS clock
9:Sound Card MPU-401 & Waves
10: IRQ port to PCI
10:VIA PCI to USB (onboard)
11: IRQ port to PCI
11:NEC PCI to USB
11:3dfx Voodoo 3dfx
12:IRQ port to PCI
12: NEC USB 2.0 controller
12: PCI Ethernet Controller
13: numeric data processor
14: Via Bus Master PCI IDE
14:Primary IDE controller
15: Via Bus Master PCI IDE
15:Secondary IDE controller
Memory:
x00000000 - x0009FFFF System extension for plug and play BIOS
x000A0000 - x000AFFFF 3dfx Voodoo3
x000B0000 - x000BFFFF 3dfx Voodoo3
x000C0000 - x000C7FFF 3dfx Voodoo3
x000C8000 - x000C9FFF Motherboard Resource
x000CA000 - x000CBFFF Motherboard Resource
x000F0000 - x000F3FFF Motherboard Resource
x000F4000 - x00000FFF Motherboard Resource
x00100000 - x07FFFFFF Plug and Play BIOS Extension
xE0000000 - xE1FFFFFF 3dfx Voodoo3
xE0000000 - xE3FFFFFF Via Tech CPU to AGP controller
xE2000000 - xE200FFFF 3dfx Voodoo3
xE4000000 - xE5FFFFFF Via Tech CPU to AGP controller
xE4000000 - xE5FFFFFF 3dfx Voodoo3
xE6000000 - xE63FFFFF Via CPU to PCI Bridge
xE6400000 - xe64000FF PCI Ethernet Controller
xE6401000 - xE64000FF NEC PCI to USB Open Host Controller
xE6402000 - xE6402FFF NEC PCI to USB Open Host Controller
xE6403000 - xE64030FF NEC Usb 2.0 enhanced Host Controller
xFFFE0000 - xFFFFFFFF Plug and Play Bios extension
The cd is into a virtual cd drive, also, with glidos patch, there was the unfinished maps exe, that guy with voodoo rush patch works, but, with original tomb doesn't 😖
Also, I disabled sound on tomb raider setup and still the same error, I wanted to test it on dos mode, but, I don't have a cd to burn it '-' also there is a virtual driver for dos, but I can't make it load the tr1 cd >.>
