Reply 4220 of 57170, by jwt27
bristlehog wrote:
http://geryon.ru/imfc_preview.jpg […]
Was IMFC manufactured by Yamaha?
Reply 4221 of 57170, by Cloudschatze
Yes, it's a Yamaha product. (Hence my use of Yamaha's logo for the photo in my QuestStudios thread.)
Similarly, you'll notice that the NEC XR385 that everyone mistakenly refers to as a "clone," is also an OEM Yamaha product.
Reply 4222 of 57170, by jwt27
Figured as much... The Yamaha PCB number (XB773) gave it away 😀
Reply 4223 of 57170, by nforce4max
Scooped up a IBM Aptiva 730 for $5 today, interesting socket 4 system but psu is bad.
Reply 4224 of 57170, by Unknown_K
Slaventus86 wrote:
Matrox Ultima for VL bus […]
MGA-VLB/4/200 on the sticker
I have one of those, can you tell me what the jumper settings on your card are set to? My card has sockets for the second bank of RAM and I need to know how to enable it.
Reply 4225 of 57170, by luckybob
Every video card i've ever worked with has ALWAYS auto-detected memory. You should be able to just add the chips and go. Jumper settings were usually only for IRQ settings or weird compatibility issues.
Reply 4226 of 57170, by sliderider
MaxWar wrote:
I am glad I do not have the CIB stuff obsession. Collecting loose hardware is hard and costly enough.
I only buy boxed when the price difference between loose and boxed is minimal. I don't have a whole lot of boxed hardware, but most of what I do have isn't especially rare and was extremely cheap at the time. Even if I was to open it all,I wouldn't lose anything.
Reply 4227 of 57170, by dirkmirk
ARK LOGIC 1000VL, got this for $20 posted doesn't seem to much interest in VLB cards on Australian Ebay considering I also got a boxed ET4000W32P not that long ago for around $25 posted.
Starting to get a collection of higher end VLB video cards, will test to see what gives the best performance/compatibility.
ET4000W32P X 2
S3 868
ARK LOGIC 1000PV
If I can grab a Cirrus Logic 5434 & an ATI mach 32/64 that would be sweet, the idea is to run a maxed out AM5X86 @ 150 or 160MHZ, would assume If I can get a stable system at 150MHZ it would give better results for gaming.
Reply 4228 of 57170, by vetz
dirkmirk wrote:
Starting to get a collection of higher end VLB video cards, will test to see what gives the best performance/compatibility. […]
ET4000W32P X 2
S3 868
ARK LOGIC 1000PV
Yes please 😀
You can post in Artex's thread if you'd like 😀
Reply 4229 of 57170, by Unknown_K
There is a large switch box by the video port, must be used for something. The PCI version of the card had a separate switch for memory I believe.
Reply 4230 of 57170, by Stojke
I have an PCI version that came with my Vectra computer.
It has two switches, one switch to either enable 2MB or 4MB, and the other switch for BIOS flashing i think.
Reply 4231 of 57170, by Slaventus86
Here is photo of switch positions:
Videocard Virtual Museum
Reply 4232 of 57170, by easy_john
Th99 has one vlb matrox video card. jumper settings - http://www.ccs-a.com/th99/v/txt/50045.txt
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 4233 of 57170, by Solarstorm
I don't know where to put this video than here.
I made a small video for the DB51XG i recently bought from eBay.
I was a bit nervous doing this video and i still am showing it to you.
If you have suggestions feel free to comment here or on the video.
Let's see how it goes perhaps i'll do some more.
https://www.youtube.com/watch?v=fejnrIDPrDU
My YouTube Channel
Reply 4234 of 57170, by Artex
No need to be nervous! Pretty decent video there. I really dig the external daughterboard host devices - never knew those existed. Quality of both the MIDI and XG stuff sounds good. Have you done any comparisons between the DB50XG and this one? I would assume they sound the same, but just curious. How about gaming - any tests done using midi-supported games?
PS - I like the way you pronounced "Yamaha" in your German accent!
Reply 4235 of 57170, by Solarstorm
I haven't compared them yet, with rendering and uploading this already took 6 hours. 😮
I now can understand why some youtubers can live from what they're doing.
Today is a Holliday in germany and that's why i was even able to do it.
Perhaps i can compare them on the weekend and film my results. 😀
I tried so hard not to sound german^^
My YouTube Channel
Reply 4236 of 57170, by Artex
It's all good - no worries! 😎
Reply 4237 of 57170, by Half-Saint
Just picked up two IBM ThinkPad T42 laptops for parts - one actually works, the other one has a dying backlight and probably a defective motherboard.
Got a GeForce 6800GT AGP and another Voodoo 3 2000 AGP (says STB as well as 3dfx on it).
Reply 4238 of 57170, by easy_john
I do not want to criticize, but the first 5 minutes of video about nothing. Show docbox and phase x64 can be take 20 seconds. Need to better plan what you want to show.
The second 5 minutes if only for sound. It could be better if you shown midi score on the monitor.
Reply 4239 of 57170, by boxpressed
Picked up a half dozen ISA sound cards over the past week for a song. Here are some of the more interesting examples:
