First post, by tuxadecimal
Hello,
I have a Pentium MMX 233 Packard Bell from 1997 without AGP and I recently picked up a Geforce2 MX200 64mb PCI video card for it which is from 2000. I know this is a crappy card but I figured this is way more then enough horse power for this machine and it was dirt cheap so it seemed like a good solution. When I tried to install it in the machine I got no video output so I tried re-seating it a few times with no luck, tried it in the other PCI slot and that didn't work either. I then tried it in a PentiumII 266 also with no luck. I finally tried it in a Pentium 4 and it worked perfectly. So I tried it again in both the PentiumII and the Pentium MMX with no luck. In the Packard Bell it does disable the on-board S3 Trio64V+ so I end up with no video output from either the on-board video or the PCI card while it is installed. I also figured maybe it was a power supply issue so I unplugged both the CD-ROM and the Hard Drive just to see if it would boot but also no go. The chipset is:
Intel® 82438VX Data Path (TDX).
Intel® 82437VX Triton system Controller (TVX).
Intel® 82371SB PCI Shipset (PIIX3).
This actually is the second of this exact model of Packard Bell I have owned, the first one I had when it was new and I put a Voodoo 3 2000 PCI card in it(really wish I still had that card to put in this one) and that card worked fine, I plugged it in and it came to life right away so I know it can work with a PCI video card. Is it possible the PCI card is 3.3v only and my motherboards are 5v only? The card has 2 slits (so the PCI connector is in 3 sections) which I was under the impression that configuration meant the card could take 3.3v or 5v. I have a PCI ethernet card in it that works fine and it has the same PCI 2 slit configuration. If anyone has any ideas they would be very much appreciated.
