First post, by keropi
Hiya!
while looking at an arcades pcb forum I stumbled upon the NEGATRON: 🤣
video: https://www.youtube.com/watch?v=YGvEjsM3SLA
http://www.dimensionengineering.com/products/negatron
It costs ~22$ shipped and people are using it with ATX psus and old arcade boards that need -5v for sound (just like the SB PRO2 / LAPC-I problem with newer psus that lack the -5v rail).
Anyone heard about that before? Are it's specs fine for audio applications? I wanna order a couple of them 🤣
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 1 of 14, by jwt27
Looks like this device turns a positive voltage into negative. ATX power supplies already have a negative -12V rail so you don't really need one of these. All you need to get -5V out of it is one LM7905 and two caps (total cost < $3). Since 79xx is a linear regulator you'll get better ripple rejection too ("~100mV typical" according to the negatron web site... vs 0.125 mV from the 79xx datasheet 😉)
Reply 2 of 14, by boxpressed
I bought one of these based on the recommendation of someone here at Vogons. Works great!
http://www.ebay.com/itm/251025150787
Reply 3 of 14, by Artex
Same here! Working great.
Reply 4 of 14, by keropi
@jwt27
thanks for the idea, it sure looks easier and cheaper with a LM7905 , IIRC you've told me this before but I totally forgot about it...
noise is a huge issue IMHO when you deal with sound stuff...
it's that schematic from the datasheet, right?
@boxpressed
first time I see this cable, it looks really nice! do you know what's inside the -5v "shrink wrapped black thingie" ? does it feel like a classic 7805 regulator?
Reply 5 of 14, by jwt27
Yes, that's the right schematic. Doesn't get much easier than that 😉
Note that the recommended cap sizes are for tantalums only. If you use normal electrolytics they should be 10+ µF (read: as large as possible)
That cable looks like a much easier solution though, and I bet you'll find the same 7905 in that heat shrink tube 😉
Reply 6 of 14, by keropi
awesome, thanks for the verification jwt27! I'll go the 7905 route my self, just another thing to build 😁
Reply 7 of 14, by boxpressed
keropi wrote:
@jwt27
@boxpressed
Hmm, I'm not sure whether there is one of those in there, but it is certainly possible. Whatever is in there is about one-inch wide.
Reply 8 of 14, by bristlehog
SB Pro 2? I thought that only SB 2.0 requires -5v from SB series.
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 10 of 14, by boxpressed
I'm pretty sure that my Yamaha YMF719 card also requires -5v.
Reply 11 of 14, by SquallStrife
Just remember that the 7905 is a linear reg, and going from -12V to -5V is a 7V gap.
If you draw just 200mA of current through that reg, it's going to pump out 1.4W of heat, which is a lot in terms of a TO-220 package device, it'll get hot quickly.
I don't know what the current requirements are for these sound/MIDI cards, in terms of the -5V supply. It could be nowhere near 200mA.
Reply 13 of 14, by boxpressed
tyuper wrote:
It doesn't require -5V. You can check this by looking on ISA slot pins and compare with contact pads on card.
http://upload.wikimedia.org/wikipedia/commons … SA_Bus_pins.png
Cool, didn't know that. Thanks.
Reply 14 of 14, by Auzner
Mfr states first thing on the product page that it's an adjustable buck-boost converter, not a linear regulator. http://en.wikipedia.org/wiki/Buck_converter More efficient but potentially more noise. These are possible to build without an IC, but you need a clock.
