First post, by chinny22
- l33t++
I found this server when I got sent to site to setup a new PC. When I went to patch the PC I noticed the server wasn’t patched in (the switch was on top of the server) in fact the only cable that was plugged in was the power cable. I asked what the server was used for and told “oh we don’t use that anymore” So I offered to turn it off as it was the noisiest thing in the office.
I didn’t really take that much notice of it, just that it was a Compaq ProLiant 1600. It wasn’t till I got home did a quick google and found out it’s a duel slot 1 server, Cool I love Slot 1!
I kept thinking about it over the next few months till I finally went round outside of work and asked if I could have it, and I could! 😀
As said I didn’t pay it much attention at the time so really didn’t know what to expect once I got it home. The first thing is the dust as you'll see from the pics!
It took 2 days to completely strip the thing, wash, wash again and put back together, it was filthy. I was surprised to see it already had 2 P2 400’s There was 2 64MB sticks of Compaq RAM as well as a latter addition of 2 256MB sticks from a Dell server. The HDD Caddies had 3x 9.1 drives and 2x 4.3 labels, what I really had were 2 Compaq 9.1 and 3x 18GB Seagate drives. It also had a Smart Array 2SL, and a HP DDS2 drive.
A lot of the manufacture dates on various parts are late 1998 and the yellow label on the front didn’t match the server name so I would guess it had more RAM and larger hard drives added and upgraded to Windows 2000. There was nothing configured to use the tape drive but I did find a tape between the server and the wall.
From the data and event log it seems that the server was last used around 2005-2006. It spent some time off but switched back on (probably by mistake) for most of 2011 and part of 2012. The logs get a bit patchy after that so it’s quite possible the machine was on but didn’t even boot into windows when I found it originally. For now here are some before pics. I’ve plans to upgrade it a bit, Max out the HDD’s in a RAID 5 configuration and use it as a backup file server. I’m getting a bit nervous about keeping everything on a 1TB USB drive. If that HDD dies I’m in trouble.
I was surprised how little dust was in the CPU/RAM cage. Didn't realise till I put it all back together they actually hang upside down. Good thinking Compaq!
And finally after it was all scrubbed clean.
One of the 9GB drives is being detected as failing soon (the noisy one) The "feet" are missing so the door drags on the floor if opened more then a few inches. I don't have the key to stop the door opening anyway so no big deal really.
If you want to see/hear the big thing in action
http://youtu.be/Y_ztYj80HSY
