My 3DMark01 Mega Thread
Reply 220 of 863, by Nahkri
Athlon 64 3200 overclocked to 2300 mhz,radeon 9600 pro.
Reply 221 of 863, by AlphaWing
noshutdown wrote:
this score is awful, sth must be wrong with your rig.
my celeron300a oc 450 and gf2ultra scores ~1600pts, and i don't think yours is only one third as fast as mine.
even my p55c oc 300 scores 640pts, and k6-3-300 scores 990, all using the gf2ultra.
We really need a 3dmark 99 and 2000 thread for older rigs.....
OK UPDATE..... I do stick my foot in my mouth alot, so I looked it over more closely.
SO........Actually your correct, after looking it over more there is something wrong with the rig, somehow the SBLIVE! has decided to share the same IRQ with the Geforce2.
Not sure this would affect the score, but it could with how the LIVE! is...
I'll repost scores for this machine when I get this to sort itself out.
I actually use this paticular machine alot 🤣 despite it being a slow celeron.
Reply 222 of 863, by kithylin
I've been doing some testing, more testing, and some tweaking and here's the final with the absolute max I can squeeze out of this setup. One of my testings I've found is the fastest drivers for nvidia with XP are 175.19, if your GPU is supported by that driver package. I tested all drivers from 163.75 to 185.85, beta and normal, this one was the fastest after all testing.
Also with what I've done to this chip I've pushed it up to 4.36 Ghz, the fastest I can get with what I've done to the poor thing. And here's the final result.
Resized for the forums:
Full Size: http://www.outfoxed.net/2001se/E3110_@_4.36_G … 2+175.19%29.jpg
EDIT: Fixed Typo
Reply 223 of 863, by Standard Def Steve
Holy hell, that's Ludicrous Speed. You're close to the ~79.5k my 4930K/GTX 780 produces, which...just shouldn't be.
I am SO tempted to install WinXP, just to see my rig distance itself a little more from yours...🤣.
"A little sign-in here, a touch of WiFi there..."
Reply 224 of 863, by kithylin
It would be faster if I hadn't been a moron and tried to sand down the top of the cpu chip and lap it (which just made it run hotter). It used to run 4.68 Ghz stable before I screwed it up. And this is just with a single 6MB-cached 45nm dual core. By this time next month I should have a 12MB harpertown quad core in there and see what that does :>
Reply 225 of 863, by Standard Def Steve
The only way a quad-core harpertown would increase your score is if it's capable of clocking higher than 4.36GHz. The extra cores won't help because the benchmark is single-threaded.
Also, all quad-core LGA775 processors are multi-chip modules. For example a Q9550 is made up of two E8300 processors underneath a single heat spreader. So even though a Q9550 has 12MB of total L2 cache, each core only has access to 6MB. The Core-2 based Xeons work the same way.
Reply 226 of 863, by kithylin
Awww sad face. That's kinda sad it won't help 3dmark 2001se much. Maybe I'll wait on the quad and get one with a higher multiplier capable of 4.5 - 4.8 then. Even if it won't help 3dmark2001se much, it'll be better for gaming, which I actually use that system for sometimes. And I'm planning on making that 775 system a "backup gaming platform" for my i7. Some day I'll end up with a 790i board and 3 nvidia cards for it.
Reply 227 of 863, by SPBHM
E2140 @ 2.1GHz
Asrock G31M-VS2 (Intel GMA 3100)
3GB DDR2 @ 880MHz "Dual Channel Flexmode"
Windows 7 and latest drivers
(I remember getting over 12K on XP and with a 4GHz E5200)
T4400 2.2GHz
Intel GMA 4500M 400Mhz (GL40 Chipset)
4GB DDR3 800 Dual Channel
i3 2100 3.1GHz
5850 @ 825/1100
H61 Motherboard
8GB DDR3 1333 dual channel
Windows XP SP3
Reply 228 of 863, by Liqu1d82
Some Windows 98 testing on ASUS CUV4X-D + 2xPIII 800EB + 2x512MB PC133 ECC
Matrox G400 @Windows 98:
Voodoo Dragon II SLI @Windows 98:
Without change something sleeps inside us, and seldom awakens. The sleeper must awaken.
http://liqu1d82.tumblr.com [My Tumblr] // https://twitter.com/Liqu1d82 [My Twitter]
Reply 229 of 863, by Darkman
my circa 2003/4 machine is finished, due to a faulty GF4 4600, I replaced the graphics card.
Abit NF7-M
AMD Athlon XP 2800+ Barton
1GB DDR PC3200 RAM
Geforce FX 5900 Ultra 256Mb (running the 93.71 drivers)
SB Audigy 2 ZS
OS of choice was Windows 2000 , I wanted to put XP on this, but given that I only have WinXP SP3 available, Win2K made more sense, certainly not going to put Win98SE on it.
on a seperate note, running the Doom3 timedemo at high settings/1024X768 , gave me a score of about 35 (can't quite remember , but it was certainly 35)
Reply 230 of 863, by SPBHM
s754 Sempron 2600+@1.80GHz
PC Chips A31G (SiS 761GX)
512MB 400 @ 450 CL3
8400GS PCI 33MHz @ 680/580
XP Sp3
Reply 231 of 863, by foey
SPBHM wrote:
s754 Sempron 2600+@1.80GHz PC Chips A31G (SiS 761GX) 512MB 400 @ 450 CL3 8400GS PCI 33MHz @ 680/580 XP Sp3 […]
512MB 400 @ 450 CL3
XP Sp3
Thats a great score for a PCI card.
DELL Inspiron 4600i
Intel Pentium 4 (Prescott, 800FSB) 3.0Ghz
1Gb DDR400 Ram (Running Dual Channel @ 400mhz, 1:1)
256mb ASUS Geforce FX 5950 Ultra AGP 8x Graphics Card / Artic Cooling NV4
Creative Audigy SB0090 Sound Card
WD 160Gb Hard Drive
Antec 380w Earth Watts PSU
10/100 NIC PCI Card
DVD-ROM / DVD-RW Drives
Running Windows XP SP3
Artic Cooler doing a fantastic job, not seen any temps over 64c, in contrast from the stock cooler 90c+
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 232 of 863, by AlphaWing
Pentium 4 Prescott socket 478 2.8ghz@ 3.7ghz 266FSB ~ HT Enabled
1GB PC3200 DDR 3-3-8 Single Channel
ABIT-IC7 MAX- i875 chipset
AGP ATI-Reference Radeon 9700pro 128mb - Omega 3.8-442 drivers
Sound Blaster Live!
Netgear GA311 Gigabit Nic
250GB Sata WD Blue
WinXP-SP3
3dmark 2001se Score =15947
Almost 1ghz OC - No voltage adjustment on the CPU, board is very picky about ram thats why I don't have a second stick and dual channel mode.... It only wants to accept Hynix Chips, or it won't boot, and I only have 1 DDR stick of that right now.
It is stable like this.
Reply 233 of 863, by foey
AlphaWing, Nice overclock. What are the temps like on the CPU?
Any OC to the 9700 Pro?
Reply 234 of 863, by AlphaWing
^Thanks foey
It's a Prescott so its hot, but it idles around 49c load is 58-60c. Cooled by an Alpha-Novatech pin style heatsink, so its quite effective.
9700pro is running stock, with its stock heatsink, which amazingly for its age, the fan hasn't gotten loud on it. Probably should replace it, but it doesn't get to hot when another 92mm fan is above it cooling the AGP slot and most of the PCI slots too. Unlike the 9800pro the stock heatsink isn't actually a piece of junk on it 🤣.
This particular machine started off life with a Northwood 2.4ghz P4 I ran with the same heatsink for 11years at 3.2ghz. I just recently decided to upgrade it when I found this CPU in a pile of junk oem matx motherboards I acquired lately.
Upgraded the ram at the same time, and found its very very picky about high density 1gb sticks, it was running 1gb x4 256mb PC2100 @ 3:2 divider before, with the northwood 🤣. So even tho its in single channel mode... PC3200 at 5:4 effectively 214mhz at 266, is an upgrade.
Reply 235 of 863, by dottoss
Specs: Retroputer
XW8200 HP Workstation
Dual Xeon Irwindale 3.80GHz FSB 800Mhz 2MB Cache
4GB Ram Elpida PC2-3200
Intel X25-m G2 80GB, ICH5
Voodoo 5 5500 PCI @ 66MHz PCI-X
Windows XP SP3
Reply 236 of 863, by Putas
I wonder if there is significant difference between Voodoo5@66MHz PCI and AGP?
Reply 237 of 863, by dottoss
Theoratically, there should be no difference when running PCI@66MHz, as that is what the AGP Voodoo 5500 variant is running also at on the AGP bus. As far as i know, the V5 5500 does not take advantage of AGP specific benefits either.
Reply 238 of 863, by Standard Def Steve
I never posted my Glide rig's score.
PIII-900, Voodoo3 3000 AGP, 320MB RAM, Win98SE
Reply 239 of 863, by KT7AGuy
Here is what I've got:
IBM NetVista A40 6578-TBU
Win98SE, with the Unofficial SP v2.1a
1ghz Coppermine
512mb PC133 RAM (Two sticks of 256mb)
3dfx Voodoo 3 3000 AGP
SoundBlaster Live Value CT4830 (Drivers-only installed)
USB 2.0 PCI adapter, NEC chipset
Intel Pro/100 VE NIC
Logitech Immersion iFeel Mouse
With my normal boot including background processes such as Daemon Tools and Logitech's em_exec.exe and the other Immersion iFeel stuff, I get a benchmark of 1471.
With all background processes killed except explorer, systray, and devldr16, I get a benchmark of 1519.
