First post, by JowyADVC
I'm just curious but is there a trick to creating and using saved states while playing games in DosBox? 😀
Use the Daum SVN Build.
Feeding Dragon
Also, ask DOSBox questions in the DOSBox forum.
Thank you guys! 😀
Btw, I got SVN- how do I use save states within it?
Moved to Dosbox general forum
JowyADVC wrote on 2014-07-10, 00:11:I'm just curious but is there a trick to creating and using saved states while playing games in DosBox? 😀
I tried a a version of qemu, with the qemu-monitor a year ago. This or vmware could be a way to use save-states. They are called snapshots in qemu. supposedly you have to use the qcow format. reference: https://eaasi.gitlab.io/program_docs/qemu-qed … e/qemu_monitor/ Found a daum version on github from 7 years ago but don't know if updated to .74-3.... with qemu where tag is a discription, commands syntax -- (qemu) savevm [tag], (qemu) loadvm [tag]
Closed.
Old thread from 2014
