3dmark99 MegaThread
Reply 80 of 409, by Darkman
my Win98SE machine
Abit BX6 r1.0
800/100 mhz Coppermine PIII @ 824Mhz
512MB PC133 SDRAM
Voodoo5500 AGP (latest official drivers)
AWE64G
SBLive 5.0
I find that Voodoo2 SLI + 3.2Ghz P4 result very interesting, obviously thats the CPU contributing to that, I doubt that in game a V2 SLI can outdo or match a V5500, though I suspect the 800Mhz CPU Im using is probably holding it back a bit.
wanted to run 3DMark99 on my Win2K machine, but sadly there are compatibility problems it seems.
Reply 81 of 409, by AlphaWing
Use the DDRAW fix for 2k\XP\VISTA\7\8, its on the first page.
Reply 82 of 409, by Darkman
ah I see it, thanks, I will try it out sometime soon.
Reply 83 of 409, by dottoss
[quote="subhuman@xgtx" wrote:
dottoss wrote:
Specs: Retroputer
Really nice score indeed. I was curious about this because I get around the same framerate in Test 1- around 152 fps with my system and a 5500 @ 188mhz but the fps on the second test are about 25 less than yours
[/quote]
Please post your system specs and if you can a benchmark on that similar system of yours 😀
Reply 84 of 409, by foey
foey wrote:
Posting my PIII rig for the first time. Its not complete yet, hence why no build log. […]
PIII Copermine 733mhz
256mb PC133 RAM
MS6309 VIA Apollo Pro133A Chipset Motherboard
32mb Creative LABs 256 Annihilator Pro AGP Graphics Card
IDE 40Gb 7200rpm / 160Gb 7200rpm Hard Drive
DVD-RW Drive
6 Channel C-Media PCI Sound Card
Windows ME
Just updated the BIOS on the MS-6309 motherboard from 1.6 to 1.9. It previously had a Packard Bell splash screen with a very cut down "AMI Easy Bios" After the update it has the full BIOS installed, settings for everything 😀 No more Packard Bell Bios screen either!
I've not touched the Bios yet, so thought I would make sure everything is running OK. Looks like I gained a 100 points from just the update 😊
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 85 of 409, by Darkman
managed to get 3DMark99 to work on my Win2K machine
Abit NF7-M motherboard
AMD Athlon XP 2800+ Barton
2GB Corsair Platinum DDR RAM
Geforce 5900 Ultra 256Mb
Audigy 2 ZS
Win2000 SP4
Reply 86 of 409, by Standard Def Steve
YES! Broke the 30K barrier!
Pentium M overclocked to 2.7GHz, GeForce 6800GT, 2GB DDR2-533, i915PM chipset.
Not too shabby for a CPU released in 2004. A bit faster than K8 clock-for-clock!
"A little sign-in here, a touch of WiFi there..."
Reply 87 of 409, by AlphaWing
Nice scores above!
I have yet to try the benchmark on a faster machine other then my win8.1 machine. which dosn't work correctly even with the ddraw fix, fps gets capped to 30. D3d overrider no help.
Reply 89 of 409, by smeezekitty
Anybody have any luck on Vista?
Another fix and another error:
"The application failed to initialize properly (0xc0000142). Click OK to terminate the application"
Reply 90 of 409, by Putas
On my Windows 7 64 the ddraw fix broke it, all that was needed is compatibility mode. Vista will probably be the same.
Reply 91 of 409, by AlphaWing
3DMark Project:
3DMark Build Version: 200
Date: 7/17/2014
Time: 12:28:07 PM
Project Name:P4 3700mhz Voodoo 3 PCI 2000 @ 166mhz
Comments: P4 3700mhz, I875, Voodoo3 2000 PCI @166mhz
Windows XP SP3. Last Official 3dfx Win2k Driver used.
Project Settings (Template):
Rendering Platform: Internal (3dfx Interactive, Inc. Voodoo Series Driver)
Resolution: 800*600
Color Depth: 16-bit Color
CPU Optimization: Intel(r) Pentium(r) III
Z-Buffer: 16-bit
Frame Buffer: Triple buffering
Refresh Rate: VSync Off
Looping: Disabled
Texture Format: 16-bit, 4444 RGBA
Run Tests: Once
Title Screen: Shown
Test Results:
3DMark Result : 6,663 3DMarks
Synthetic CPU 3D Speed : 50,739 CPU 3DMarks
Rasterizer Score : 3,024 3DRasterMarks
Game 1 - Race: 69.6 FPS
Game 2 - First Person: 63.9 FPS
Fill Rate : 156.9 MTexels/s
Fill Rate With Multi-Texturing : 307.9 MTexels/s
2MB Texture Rendering Speed: 549.4 FPS
4MB Texture Rendering Speed: 575.2 FPS
8MB Texture Rendering Speed: 523.8 FPS
16MB Texture Rendering Speed: 4.1 FPS
32MB Texture Rendering Speed: 2.1 FPS
Bump Mapping Emboss, 3-pass: 141.2 FPS
Bump Mapping Emboss, 2-pass: 186.0 FPS
Bump Mapping Emboss, 1-pass: Not Supported
Point Sample Texture Filtering Speed: 102.4 %
Bilinear Texture Filtering Speed: 100.0 %
Trilinear Texture Filtering Speed: 56.5 %
Anisotropic Texture Filtering Speed: Not Supported
6 Pixel/individual: 1,280.1 KPolygons/s
6 Pixel/strips: 1,279.7 KPolygons/s
25 Pixel/individual: 1,277.6 KPolygons/s
25 Pixel/strips: 1,283.9 KPolygons/s
50 Pixel/individual: 1,290.0 KPolygons/s
50 Pixel/strips: 1,285.8 KPolygons/s
250 Pixel/individual: 550.6 KPolygons/s
250 Pixel/strips: 557.3 KPolygons/s
1000 Pixel/individual: 149.1 KPolygons/s
1000 Pixel/strips: 149.5 KPolygons/s
System:
Windows Version: Windows 4, Build 2222
DirectX Version: 4.07.00.0700
Bios Version: Not detected
Bios Date: Not detected
Total Physical Memory: 1,024 MB
Free Physical Memory: 824 MB
Processor:
Processor Type: Unknown
Processor Speed: 3667 MHz
Processor Caps: MMX SSE
L1 Cache Size: None
L2 Cache Size: None
Desktop:
2D Display Adapter Name: 3dfx Interactive, Inc. Voodoo Series Driver
2D Display Adapter Driver Date: 11-2-2000
Monitor Name: Not detected
Monitor Driver Date: Not detected
Desktop Resolution: 1280*1024
Desktop Color Depth: 32-Bit Color
3D Accelerator:
Driver Name: 3dfxvs.dll
Driver Version: 0.00.00.0000
Total Video Memory On Card: 16,251 KB
Total Texture Memory: 11,131 KB
Bus: PCI
Supported Features:
16-bit Rendering
Point Sampling
Point Sampling With Mip-Mapping
Bilinear Filtering
Bilinear Filtering With Mip-Mapping
Trilinear Filtering
Specular Gouraud Shading
Vertex Fox
Table Fog
W-Fog
Sub-Pixel Accuracy
Alpha Blending
Addivitive Alpha Blending
Multiplicative Alpha Blending
Vertex Alpha Blending
Vertex And Texture Alpha Blending
Screenshot Score = 6663 CpuMarks=50739
Voodoo 3 is being oced to 3000 Speeds, as I did not want to dig out my PCI 3000 from my PII 450 system 🤣 .
Kinda expected a better score, but I think the drivers are limiting it a bit, as the 2000 drivers are not as mature as the 9x, also the 2k drivers are being run in XP3, 3dfx tools doesn't work at all as a consequence.
Used Voodoo Control to disable V-sync.
System was also very picky about slots with this card, Would not post in anything but PCI slot 3, and thats with every other PCI card removed too.
Reply 92 of 409, by JayCeeBee64
Rank Retired
Retired
I usually don't run 3D benchmarks on any of my builds, but just for fun I gave this a shot 😀
Pentium 4 2.4GHz Northwood, Soyo P4I-845PE, 512mb DDR-333 ram, NVIDIA GeForce 4 Ti 4200 128mb AGP, DirectX 8.1b, Windows 98SE
Used to have a GeForce FX5500, but had unexpected issues with some DirectDraw games and replaced it with the GeForce 4. Using 40.72 WHQL NVIDIA driver, VSync disabled.
Pentium 166MMX, Asus TX97-XE, 64mb EDO ram, 3dfx Voodoo 2 1000 12mb, DirectX 7.0a, Windows 95A
I can't quite remember what driver the Voodoo 2 is using (I believe is 3.03.00). Couldn't disable VSync so I just ran it as-is. 2D card is a Matrox Millennium II 4mb.
Core i5-3350p, MSI Z77A-G43 (MS-7758), 8gb DDR3 ram, NVIDIA GeForce GT 640 2gb PCIe, DirectX 11, Windows 7 Ultimate SP1 64-bit
I didn't expect 3DMark99 to run on Win7 64, but it did (thanks Putas for the tip). More or less what I expected of my middle-of-the-road main rig. Using 310.90 WHQL NVIDIA driver, VSync disabled.
As a final note, no overclocking, memory timing or voltage changes were done. All tests were run with BIOS defaults.
Ooohh, the pain......
Reply 94 of 409, by Standard Def Steve
The shittiest socket A system in the world:
Athlon T-bird 1.33GHz, Epox board with no AGP, 512MB of PC133 SDRAM, ProSavage IGP
Reply 95 of 409, by AlphaWing
Nice scores Jaycee especially the Pentium 166mmx.
SD-Steve, Does that Integrated pro savage display everything correctly in the benchmark?
It is an s3 chip, so just curious if it does.
Reply 96 of 409, by Standard Def Steve
Yep, everything looked OK in 3dmark 99 and 2000. Most of 3DMark01 even looked normal. GT2 (Dragothic) had quite a bit of color banding, despite running in 32-bit color.
Reply 97 of 409, by AlphaWing
That is surprising I'd expect it to display like the Virge chips, textures missing or incorrectly rendered etc 🤣 !
Reply 98 of 409, by Putas
Savages were mature full featured chips.
Here is my database of vintage3d scope and some more cards: http://www.vintage3d.org/data/MOJE.3DB
There is a problem though, image quality results were not saved properly, there were few results pasted over all other cards and now completely disappeared. Anybody knows what's up with that?
Reply 99 of 409, by Darkman
made some big changes to my Win98 machine, I wanted a 1Ghz machine, but native 1000/100Mhz PIIIs are extremely rare and expensive, and I couldn't find any decently priced powerleap adapters either. I ended up going the Athlon route and getting an Abit KT7-RAID, which has a useful ISA slot , and a 1Ghz Athlon 1000. Also added in a 350w Enermax PSU from another build, to replace the generic 230w PSU I had in there.
Abit KT7-RAID (latest bios and ViA drivers
Athlon 1000
512 PC133 SDRAM
Voodoo 5500 AGP (latest official drivers)
Sound Blaster Live 5.1
SB AWE64G (ISA)
Win98SE
not a big fan of the VIA chipsets (certainly compared to the 440BX) but it will do, the CPU came with a Zalman fan shaped cooler which looks cool .
