First post, by marseugene
I got old dos based application and running in dosbox.
But found that I can not do copy and past between dosbox and windows 7.
How can I fix the problem?
You cannot fix this. There is a kludgy workaround somewhere in the forum (search topics by emendelson). Try whether that suits your needs...
Thanks for your quick reply Dominus. I just look it arround, but only can see a way( send the text from doxbox to windows) which using DOSBoxSnipper. How I can do if I want send txt from windows to dosbox?
Thanks
Search for topics by emendelson and you will find both an utility to do that and a special dosbox version. Advanced search, author emendelson, search in topics...
I found many some information regarding to autoit, I wonder if it is a solution what I am looking for?
Search better 😉
