First post, by Guest
For a long time, I've wanted to run my old BASIC code that used the Tandy 3-voice system. On my current modern PC, those old BASIC programs run (meaning they don't crash and appear like they are trying to play) however, I never hear any sound.
So am I using a poor version of BASIC? Or do modern PC's not allow for the Tandy 3-voice system via BASIC to work? If the answer is "yes" to that previous question, would DOSBox allow them to work? Thanks.
Reply 1 of 5, by Harekiet
Rank DOSBox Author
DOSBox Author
Perhaps the lack of tandy 3-voice hardware on non tandy systems could explain it
Reply 2 of 5, by Guest
Meaning it's ONLY a hardware issue, and therefore DOSBox won't help me any?
Reply 3 of 5, by Harekiet
Rank DOSBox Author
DOSBox Author
Dosbox can be setup to emulate a tandy like machine and it has emulation for the tandy 3-voice
Reply 4 of 5, by Guest
Very cool! So do I only need DOSBox? Or do I need VDMSound as well? (I'm not sure which does what -- never been here before or worked with emulation).
And lastly... where in the world did you get that avatar!? 🤣!
Reply 5 of 5, by Harekiet
Rank DOSBox Author
DOSBox Author
Yep dosbox should be enough, think the tandy sound is enabled by default so find the dosbox starters guide on the forum here and use that.
And this avatar...
