First post, by DNSDies
I'm trying to get a Thinkpad X20 together for some early windows/late DOS games, and I've run into a snag with getting some Sierra games to work the way I want.
The X20 has a Crystal Semiconductor CS4281 sound chip, which works in DOS, but gives TERRIBLE OPL emulation with chirpy tinny percussion notes, but the WSS (Port 388) FM Wavetable is very nice.
If I start Windows 98 with the VXD Drivers (from the Lenovo website), I get SB DAC working fine in DOS.
If I then change the drivers over to the WDM Win98SE drivers, I KEEP the SB audio, and Windows will enable the FM Wavetable stuff on MIDI, resulting in wonderful music.
Is there any way to get this effect without swapping and re-swapping drivers after each restart?
Here's the datasheet on the chip, if it helps:
http://ecee.colorado.edu/~siewerts/ecen/hardw … ecoder_Spec.pdf
Reply 2 of 7, by leileilol
You should be able to use Hal9000's Megabuild for OPL passthrough capability in Windows 98. PIII 600MHz should be enough for many games out there, but definitely not for the 'late' ones through emulation.
collector wrote:
In addition this forum is for DOS games, not DOSBox.
Actually he's trying to use a retro laptop for both native gameplay and emulation, and the specs are rather nice for this purpose (in theory)
Reply 4 of 7, by DNSDies
it's "game specific" in that it's an attempt to get General Midi in Quest for Glory 4 in Win98 on real hardware in the windows 98 "dos box" (not DOSBOX, the emulator).
Reply 5 of 7, by Mau1wurf1977
On the Thinkpad website, are there drivers for DOS as well? I mean proper DOS, not for Windows.
Because running a DOS game from within Windows is not the best way of doing things 😀
My YouTube channel
Reply 6 of 7, by DNSDies
there is , and there isn't.
There's a Windows 95 VxD driver that also installs a DOS driver. It works, mostly, but I can't use the midi device on Address 388.
