Reply 20 of 29, by Kreshna Aryaguna Nurzaman
Hmmm...
Some A/V receivers can up-convert its analog video signal into 1080p HDMI out.
So, which one will be less blurry?
Scenario 1:
[GTX 280] ---direct DVI or HDMI---> [Monitor]
Scenario 2:
[GTX 280] ---DVI to VGA---> ---VGA to S-Video---> [A/V Receiver] ---HDMI---> [Monitor]
Yup, between the video card and the A/V Receiver, there is a convoluted conversion from VGA into S-Video, but then the A/V receiver will upscale the analog video signal into 1080p and then send the resulting digital video signal to the monitor via HDMI.
Last edited by Kreshna Aryaguna Nurzaman on 2014-07-26, 12:54. Edited 1 time in total.
Kreshna Aryaguna Nurzaman.
Reply 22 of 29, by Kreshna Aryaguna Nurzaman
Mau1wurf1977 wrote:
Is this a trick question?
1 of course!
It's not a trick question; I just wonder how good a receiver's upscale conversion is. Is it good enough to outweigh the signal degradation from converting DVI out to VGA and then to S-Video?
Too bad no AV receiver has direct VGA input, thus avoiding the conversion from VGA to S-Video.
Has anyone ever tried such convoluted experiment before? Just out of curiosity? I don't really mind convoluted configuration as long as it yelds the best result.
Reply 24 of 29, by obobskivich
Mau1wurf1977 wrote:
Technically impossible...
Agreed. It's the conversion to S-Video that will destroy your signal (especially since s-video is very resolution limited). Going from YPbPr at high resolution (like 1080p) and letting the receiver do an A/D conversion wouldn't be a bad connection though - similar to VGA into your LCD monitor (although the AVR may give you more control/adjustment options).
Reply 25 of 29, by Kreshna Aryaguna Nurzaman
I see, thanks!
Problem is, even if I'm using YPbPr instead of S-Video, I'll start from low resolution anyway - 640x480 and the likes. 😁
Reply 26 of 29, by obobskivich
YPbPr will have much better color separation/definition than S-video, so it would be worth setting it up that way vs S-video if possible (although an old graphics card with YPbPr may not be as easily found as one with S-video). Colorspace converters exist to translate VGA (RGB) to YPbPr, which may be a reasonable consideration if you want to go through a receiver.
Reply 27 of 29, by Kreshna Aryaguna Nurzaman
Interesting, and it may be worth trying. 😀
Anyway, would an Atlona VGA to HDMI scaler yield better result than (a) converting VGA to YPbPr, then (b) upscaling and converting YPbPr to HDMI on a receiver?
Reply 28 of 29, by obobskivich
That's a trickier question - it depends on how good the Atlona is at A/D conversion and scaling I would guess. Newer graphics cards will generally be able to output YPbPr natively so this would only be a relevant discussion for an old card that would need conversion one way or another, and then it would just come down to which device had the better conversion quality - the VGA to YPbPr adapter or the Atlona HDMI adapter.
Reply 29 of 29, by Holering
Yes. If you want the cleanest signal, you need the least conversions possible.
EDIT:
You still have the issue of figuring out what does oversampling. If you don't want blurriness, you need oversampling.
