First post, by Stojke
- l33t
What is the best way to test AMD 5x86 P75 overclock stability?
I have obtained an Biostar MB-8433UUD-A Version 2 that can push the clock to 40 MHz and 50MHz. And i have 4 AMD P75s (2x ADW and 2x ADZ version).
Sadly the battery is as dead as a battery can be, and its soldered, so i will need to remove it. But unlike one person who had problems because of that mine passes the boot phase.
