First post, by Zenyth
All Build Engine games seems to get flickering on sprites if I use 1024x768 as my screen resolution (reads blood, duke3d, redneck rampage, etc). Is there any workaround to fix that?
Reply 2 of 11, by ColdBrain
Does this happen only at 1024x768 or at all resolutions?
If it happens at all resolutions, I have this problem too. This happens with very fast CPUs. For example, on my desktop (Core i7-2600 @ 3.4GHz), the HUD sprites flicker a lot, but on my laptop (Core i5-3337U @ 1.8 GHz) it doesn't happen.
Setting machine to vesa_nolfb will fix the problem, it's a VESA 2.0 mode simulated graphic card the same way as the svga_s3 setting. Limiting CPU cycles also works, but I don't know the ideal cycle setting. 150000 cycles should be adequate for 800x600 resolution (obviously more for 1024x768), but I think it depends on the machine.
Reply 3 of 11, by Firtasik
vesa_nolfb can cause screen tearing. This should be a better solution.
11 1 111 11 1 1 1 1 1 11 1 1 111 1 111 1 1 1 1 111
Reply 4 of 11, by ColdBrain
Yeah, I get lots of tearing with vesa_nolfb. How to use the file in that attachment, though?
Reply 5 of 11, by Firtasik
Unpack nolfblim.ren2com to a game folder, rename nolfblim.ren2com to nolfblim.com and add nolfblim.com to dosbox.conf just before game.exe (like blood.exe or duke3d.exe).
Reply 6 of 11, by ColdBrain
Thanks, works just fine! I was trying to launch it like bMouse but it was the wrong way. Capped at 35 fps on my machine, though (measured with Fraps).
Reply 7 of 11, by Firtasik
What game? Bandicam shows me max 70 fps in Blood.
Reply 8 of 11, by leileilol
Also this flickering is actual behavior that happens on real machines of a very high speed. Not a DOSBox bug. FYI 😀
FUCK "AI"
Reply 9 of 11, by ColdBrain
Blood itself. Without nolfblim it reaches over 60 fps. My monitor's refresh rate is 60 Hz.
Reply 10 of 11, by Firtasik
Hmmmmm, that's weird. There's a cheat for displaying fps, press t and enter rate. Does it reach max 35 fps too?
Reply 11 of 11, by ColdBrain
Yes, it does. Actually, NOLFBLIM lowers my overall fps instead of capping it. I get higher fps if I look at a wall, but that also happens without it, and, without the app, my PC runs Blood through DOSBox without breaking a sweat.
