First post, by EverythingOldIsNewAgain
Of the non-surface mounted 5x86's, it appears there is the ADH, ADY, ADZ, and BGC models. My understanding is that the chips were manufactured through 1999 although I've read some reports of later dates (it seems AMD manufactured other 486's into the early 2000's).
Is there a general consensus on which of these models and/or which production dates are most reliable at higher clock speeds?
As far as I know a few of the early chips were on the 0.5 micron process but the vast majority were on the then-AMD standard 0.35 micron process. So I'm guessing that's not much of a differentiator.
Is it a crapshoot or is there any science behind it? 😊
Reply 2 of 4, by EverythingOldIsNewAgain
ElectricMonk wrote:
Har har! There's a bing one too.
I'm aware of the general details (as I noted), I just wanted to know if there was a consensus around here as to which ones (if any) clocked better.
Reply 3 of 4, by ElectricMonk
I think the "chip collection" links (3 or 4 of them) had lots of details, and might have contained what you're looking for.
But yeah, I was also just going for the cheap laugh. 😁
Reply 4 of 4, by EverythingOldIsNewAgain
In that case, I'll check those out.
No worries, I've done it myself before. 🤣
