First post, by borgie83
- Oldbie
Ok, so I have just recently replaced a PCI Diamond S3 Trio64V+ with a AGP Diamond Savage 4 Xtreme on my Pentium II Windows 98 SE build.
After doing the upgrade, I'm now encountering issues with various versions of DirectX. I should also mention that I have a Diamond Voodoo 1 connected to the Savage 4 Xtreme. This same Voodoo 1 used to be connected to the S3 Trio64V+.
Originally before upgrading to the Savage 4, I was using DirectX 8.1 with no issues whatsoever. Here's what's happening with DirectX:
DirectX 6.0 - Won't Install at all. Gives an error on install startup.
DirectX 6.1 - Installs fine but gives issues with DirectSound but not with DirectMusic.
DirectX 7.0 - Installs fine but gives issues with DirectSound but not with DirectMusic.
DirectX 7.0a - Installs fine but gives issues with DirectSound but not with DirectMusic.
DirectX 8.0 - Installs fine but crashes Windows upon running DXDIAG.
DirectX 8.1 - Installs fine but crashes Windows upon running DXDIAG.
I should also mention that DirectX 8.1 is the only version that allows me to have sound working 100% (SFX and Music) using my SB Live but again DXDIAG crashes and so does 3DMark.
I've tried reinstalling the Sound Blaster Live drivers each time as well as reinstalling 2 versions of the Savage 4 drivers. Those being the S3 latest drivers and the latest Diamond drivers. All with no luck at all.
Just don't understand how a Trio64V+ can work flawlessly under DirectX 8.1 yet a newer Savage 4 Xtreme cannot.
