run roland sc55
First post, by Dunkill
Hi all 😀
I recently bought a roland sc55 for my 486 pc config and i can't get it to work.
I have a gameport -> midi cable.
I plug the port (15 pins) on the gameport of my AWE64 then i plug the midi port "out" in the input "in" of the sc55 and vice versa.
i put "sound canvas" in the setup of doom and run the game.
No song. Nothing on the sc55 screen.
I did something wrong ?
Reply 1 of 15, by PeterLI
Did you check the I/O (should be 2/9 ideally) and IRQ (should be 330 ideally) for the MPU-401? Does the MPU-401 conflict with anything else? Good luck! Do you see any MIDI input on the SC-55 LED? Did you connect speakers to the SC-55? There is no need whatsoever for MIDI OUT from the SC-55 to MIDI IN to the AWE32 BTW.
Reply 2 of 15, by vetz
He is using a AWE64 card, not an Roland MPU-401, meaning IRQ is irrelevant if the rest of the soundcard as been setup correctly.
1. Do regular sound work in Doom?
2. CTCM is run in autoexec.bat?
3. I/O address are the same in config and Doom setup?
Reply 4 of 15, by PeterLI
Reply 5 of 15, by vetz
PeterLI wrote:
Of course it matters. When you play to MPU-401 it utilizes both IRQ and I/O. Regardless of whether it is software or hardware.
Using AWE64 I would highly recommend you set IRQ to the default 5 to make it easier for games using general MIDI to recognize it by default. The 2/9 IRQ is for much older games using LA synth.
Reply 6 of 15, by bjt
While interrupts may be generated, only a very small number (~20) of old games use them.
They're not relevant to any game that natively supports Sound Canvas.
Reply 7 of 15, by Mau1wurf1977
The only cable that needs to be connected is the MIDI out from the AWE into the MIDI in on the SC.
Now the AWE64 has a jumper to enable internal GM emulation. Check if this jumper is set or not. I can't remember what it's called but I made a video about enabling GM emulation: http://youtu.be/t0OIW0YpS1c
So the jumper should be the set to the opposite as in this video 😀
My YouTube channel
Reply 8 of 15, by Dunkill
ty for replies
i will check all of it.
But a don't understand because i have roland mt32 which work like a charm in my awe 64 so i suppose my setting is good.
but sc55 do not work
Reply 9 of 15, by Mau1wurf1977
🤣 you could have mentioned that earlier 😀
My YouTube channel
Reply 10 of 15, by keropi
well maybe it's a dead sc-55 , the same connection rules for the mt-32 apply to the sc-55 as well...
edit: try playing the build-in demo songs, do they work?
HOW TO LISTEN TO ROM PLAY Demo songs that make the best use of the internal Multi-timbre sounds are stored within the Sound Can […]
Demo songs that make the best use of the internal Multi-timbre sounds are stored within the Sound Canvas. The process of auto-playing these demo songs is called ROM play.
1. While holding PART < and > , turn the power on. “Init GS, Sure?” will be shown in the display.
2. Press ALL to execute (Press MUTE to stop the operation).
3. Select a song with the PART < and > buttons.
4. Press ALL to start the song. The volume level of each instrument will be shown on the bar graph display. All songs will be played in order beginning with the song you chose.
5. Press MUTE to stop playback.
6. Press ALL and MUTE simultaneously to return to normal playing status.
Reply 11 of 15, by Dunkill
sorry 🤣
you're right !
i just did the test, i unpluged the midi "in" from awe64 of "out" from sc55 and it's working !
and when i plug the cable it's not working again.
Why ?
Reply 13 of 15, by Dunkill
sure haha
but i'am wondering : have you a list of sc55 compatible games ?
Reply 14 of 15, by PeterLI
Reply 15 of 15, by Mau1wurf1977
Dunkill wrote:
sure haha
There is likely something on Wikipedia. But honestly almost every game after Strike Commander / Day of The Tentacle / Space Quest 5 will support GM.
My YouTube channel
