First post, by GeorgeMan
Hello forum!
After some DAYS of searching, I don't seem to be able to find what to do to have functional USB ports on my 430vx motherboard under Windows 95OSR2.5
In the past I've made it work with the supplement and the drivers for 430tx directly from Intel.
But now I cannot find any appropriate driver and every one I tried didn't remove the question mark in the device manager.
So is it not going to function? Is there any solution? Please help! 😕
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 2 of 17, by Nahkri
Have u installed the two usb suplements from the windows 95 cd?
They have to be installed after u finished installing windows 95,after that u install chipset drivers and finally this usb driver.
http://toastytech.com/files/cruzerwin95.html
Also don't forget to check the usb conector if it's cables corespond to the usb pinout on the motherboard.
Reply 3 of 17, by GeorgeMan
The usb supplements and the pinout is correct, but I don't seem to be able to find the correct chipset/usb driver as none of what I've found removes the question mark. 🙁
On intel's site the isn't any 430vx driver as far as my search skills tell me. 😜
Reply 4 of 17, by NJRoadfan
You might have to install a USB card. Most 430VX boards had USB ports that simply didn't work.
Reply 6 of 17, by GeorgeMan
Hmmm, that was the kind of answer I was hoping for!
Thanks, will try it and post feedback in a day or two. 😀
Reply 7 of 17, by GeorgeMan
Well, I guess I'm out of luck this time.
The inf updater indeed updated some files, but the exclamation mark was never removed.
I formatted it and installed 98se from scratch. Now the controller is installed, but I have an exclamation mark at the root hub...
So I guess it can't be helped...
I'm currently searching for the fastest and easiest available method of file transferring between a windows 8 pc and this. Via ethernet I suppose?
I installed a 3com pci lan card and now the old machine has internet, but I'm totally dumb on ftp file transfers and how to set them up... 😒
Reply 9 of 17, by raymangold
My favourite Pentium 1 is a 430VX-based system (Triton II), and I can confirm USB works perfectly fine for me under 98SE.
EDIT: why not just transfer files over a local network share? That's what I do sometimes...just create a shared folder on your internal LAN and point the UNC path to the computer that needs to access it.
I'd also like to add that Triton II machines are pretty exotic due to the bizarre memory intel implemented, I don't know of many [others] with them. I do happen to own a handful of 128 MB EDO DIMMs.
Reply 10 of 17, by GeorgeMan
Alright, I want this system for dos and windows 3.11 really, so the usb would have helped for transferring files in it.
Network sharing between an 64bit windows 8 machine and win 9x just does not work, the windows 8 pc finds the shared folder, but I'm out of ideas what to input for username and pass when it asks...
Reply 11 of 17, by vetz
It does work. Just share the whole harddrive with full access in Win9x. Then you have full access to that machine on your modern computer and can copy over the files you need. I use this system on all my 486+ systems. If you try and access the Windows 7/8 computer from the Win9x you get a username/password prompt, so it only works one way.
Reply 12 of 17, by GeorgeMan
I just tried to share the whole hard drive in 98.
I gave a full access password, and I have enabled the file sharing. Also, on win 8 side, I've turned network discovery on and disabled security to the point the OS leaves me.
But I still get the username/password thingy on the 8 machine, when trying to access the 9x shared folder, which it indeed discovers correctly.
What am I doing wrong here?
Reply 13 of 17, by konc
Just another idea to think about, I've setup a basic ftp server on my main machine (configured only for local access, service running manually etc) and I just run an ftp client on the machine I want to transfer the files. There are ftp clients for everything, dos, win3.1... so this always works as long as you have a network card functioning. You don't even need to deal with windows file sharing, problems between different versions and all these.
As for your last post, it's not clear what additional things you might have tried, but if you haven't already create on the newer machine a user account exactly as that of the windows 98 pc.
It should have worked though by just writing on the window asking for username/password
user: <WIN98 MACHINE NAME>\<win98 user>
pass: <win98 user password>
(yes, with machine name before user)
Reply 14 of 17, by oerk
Have you tried sharing a specific folder with a specific username and password on the 9x machine? Sorry, don't have a 9x machine here, and I can't remember if this option exists.
Having a NAS is great for that. Every machine with SMB or NFS support can access shares. All Linux/Android/Windows machines at my house can share files without any problems whatsoever, regardless of OS version.
Seconding the FTP option if you can't get SMB to work.
Reply 15 of 17, by idspispopd
If you are using W9x only for file transfer: That's not really necessary. WfW 3.11 can do TCP/IP, at the time I connected it to another machine running Linux with Samba. I don't know about the driver situation, though - the NIC I used at the time was automatically detected by WfW 3.11.
Reply 16 of 17, by Holering
You have to install the usbsupp package in the Windows 95 OSR2.5 cdrom. It's in the
CDRIVE:other\updates\usb
folder. Install usbsupp.exe (this is a royal pain because you must finish an entire scandisk), reboot and install USBUPD2.EXE (this one finishes without any prompt) and reboot again. It's a pain but this gives you USB 🤣.
Reply 17 of 17, by smeezekitty
I know file sharing between 7 and 9x and even 3.11 works fine.
I have no idea about W8 but I do know that sharing your whole drive isn't a good idea.
