First post, by squeege321
Good morning all,
I've done some digging through this forum and the internet, but haven't found any instances of the issue I am having.
I've got DosBox 0.74 installed, and am trying to mount the game "Exploration". The game provides music from the CD itself. My understanding is that the -usecd * command is used to allow for this, but I use and get the following:
Z:\>mount d c:\dosgames\Explore -t cdrom -usecd 0 -label Explore
Message not Found!
If I remove -usecd 0, the mount is successful. Sound effects will work via sb16, but no music.
mount -cd gives
CDROMs found: 2
0. D:\
1. E:\
Any ideas?
Thanks!
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
-usecd is intended to be used when mounting the path of a real cdrom.
so mount d d:\ -t cdrom -usecd 0 -label Explore
The message not found errormessage is an error in DOSBox. Thanks for the report
This probably needs to be added in DOS_SetupPrograms
MSG_Add("MSCDEX_ERROR_PATH","MSCDEX: Specified location is not a CDRom drive.\n");
Water flows down the stream
Reply 2 of 5, by squeege321
Ahh, that makes sense, thanks Qbix.
The sound prog for the game has a menu for 'Select Music Source' with options of 'CD Audio' and 'No Music'. Are there any additional params I should be loading the cd with to allow for the 'CD Audio' option?
I know its just as likely that the game may not be 100% compatible, so if that's the case no big deal. I just want to make sure I'm not missing anything.
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
nah, the label is probably not required either if you have the original CDROM in your drive.
Reply 4 of 5, by squeege321
I don't have the original cd. Just got it in my head that -usecd allowed for some sort of extended cd capability.
Thanks for the responses, happy Saturday 😀
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
it does, but it needs a CDROM (and drive) to work (hence the name use cd)
