Reply 40 of 53, by gerwin
- l33t
wrote:You can use any external module you like as external modules will not suffer from the hanging note bug.
When you use a multimeter to compare the joystick connector midi signal path with the one to the daughterboard header, you will find that these use the exact same signal. So I have to disagree.
