First post, by DeadmanDave
I've installed Tie Fighter using DOSBOX.
It only played once when I installed the game and clicked "exit installation and run Tie Fighter".
But now, every time I try to play the game, it goes to the installation screen with all installation options disabled except "uninstall".
I've had this problem for months now, and none of the websites I've visited so far have helped me.
In DOSBox, I type:
mount d D:\ -t cdrom -usecd 0 -ioctl
mount c C:\DOSGames\DOSGAMES\tiecd
C:
tie
Then, the installation screen comes up instead of the game.
Reply 1 of 9, by ripa
You need to mount the directory above the installation directory. I.e.:
c:
cd tiecd
tie
Tie Fighter installer (at least Collector's CD-ROM version) writes C:TIE.CD file that tells where it is installed. In your case and probably by default it would contain C:\TIECD
Reply 3 of 9, by DeadmanDave
Still getting the installation screen after typing
c:
cd tiecd
tie
It is the Collector's CD-ROM.
I'm going to try a reinstallation and see if I can change that "C:\TIECD" command.
Reply 4 of 9, by DeadmanDave
Nope!
It didn't even let me reinstall it.
I had to retrieve the game files out of the recycle bin and put them back in the "DOSGAMES" folder.
I'm still getting the same installation screen instead of gameplay.
Also, I found a "TIE.CD" file outside the "DOSGAMES" folder.
Should I move it?
Reply 5 of 9, by ripa
I don't know how your Tie Fighter files could possibly have ended up in Windows' Recyling Bin, but how about you start over and explain step by step how you're installing the game including all the mount commands.
The game has installed and worked perfectly fine for me this way:
- mount some existing directory as C,
- mount the optical drive, Daemon Tools virtual drive, or image file as D
- in Dosbox, switch to D: and run the installer
- after installing, switch to C:, cd into the game directory (C:\TIECD by default if I remember correctly) and run the game
- in the future, always use the exact same mounts as when the game was installed
edit: you can even run the installer from the CD and it will give you the option to play the game, no need to CD to C:\TIECD.
Reply 6 of 9, by DeadmanDave
The commands I used to install the game:
Mount d D:\ -t cdrom
d:
install
Installed using "maximum install" and "express install".
Music and sound testing worked.
I clicked "exit and run Tie Fighter".
Game worked, but when I quit and tried to play it again, the "install" screen came up.
Using the commands, "mount d D:\ -cdrom", "mount c C:\DOSGames\DOSGAMES", "D:", "install" I got that screen your showing me, but when I clicked "play", I got this error message:
ERROR #3: You must insert Tie Fighter CD into your CD ROM drive. If the CD is already in the drive and you still get this error, then check to make sure that your CD ROM drivers are loaded.
When I clicked "install" on that same screen, all the "install" options were disabled whether the game was installed or not.
I understand "switch to c:", but I don't understand "cd into the game directory (C:\TIECD by default if I remember correctly)".
Reply 7 of 9, by ripa
The commands I used to install the game: […]
d:
install
So you did not mount C: at all? Then the game did not get installed. You have to mount C: also when you install the game, not just when playing afterwards.
Your D mount command is missing the '-t' before 'cdrom'.
I understand "switch to c:", but I don't understand "cd into the game directory (C:\TIECD by default if I remember correctly)".]
c: <--- switches to c:
cd tiecd <--- switches to c:\tiecd
But you don't need to do this since the installer also allows you to play.
Reply 8 of 9, by DeadmanDave
IT WORKS!!!!!
Thank you! And thank the good Lord in Heaven!
Did a fresh reinstallation with "c C:\DOSGames\DOSGAMES" mounted.
And the "cd tiecd" command works now.
After that, I hit "Tie", and the game begins.
Again, thanks a bunch!
Reply 9 of 9, by ripa
Enjoy the best game ever released 😀
