Reply 20 of 22, by Mau1wurf1977
- l33t++
wrote:Had the same issue with the P3B-F as mentioned in this thread when I tried to connect a 250GB IDE drive. I used SeaTools for DOS and limited the size to 137GB (267000000 LBAs) 😀
Made this video and devoted it to you: http://youtu.be/D__2uIai0cU
Being able to turn a modern drive into a drive with ANY capacity is such a useful trick 😀
Not sure why I didn't think of it and stuck with the 32 GB option.
