First post, by Guest
It wont let me type anything else in the autoexec.bat (I have 98 and im using the alpha) Whenever i try to type somthing nothing appears in there and the program is still responding, anyone know why it wont let me?
any help would be good since its been more than a day and i realy want to play my game
Thanks for all the help motherfuckers
no problem.
If you can edit autoexec.bat look for a readonly attribute on the file
(right click , properties, remove any read-only thing)
Water flows down the stream
@Guest You should consider using your small mind before typing anything next time... Ever tried search'ing for an answer yourself? No I didn't think so 😒
Actually i did try searching for the answer, and never got one. But it doesnt matter now because i dont feel like playing the game, sry if i was a jackass i was just mad
