First post, by theelf
I bought a ISA card Roland S-MPU/AT
S-MPU/AT
http://xv2020.s14.xrea.com/index_old.html
The card on back, have adress and int switch, a midi connector, and two rca in/out... Is only the ISA card, without the dongle
Anyone can tell me what exactly I bought? no idea here 😊
Thanks
Reply 1 of 10, by Jepael
It's a MIDI adapter card so you can connect it to various MIDI devices like keyboards and sound modules.
Rather boring without the breakout box, but, most likely you can make an adapter cable yourself if you want MIDI out (in?).
See the details from the link below.
http://en.wikipedia.org/wiki/MPU-401
Reply 2 of 10, by keropi
AFAIK these newer models lack the "Roland Intelligent MPU" feature, it's just an UART MPU-401 device that is meant to be used for serious stuff... 😁
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 3 of 10, by Stojke
Its something i always wanted 🤣
Reply 5 of 10, by FeedingDragon
The S-MPU (or Super MPU) is an intelligent model. Not exactly useful without the breakout box. It's main advantages are extra features (metronome, timing & such,) external settings so the I/O & IRQ can be changed without opening your case, and 2 each MIDI input & Output (on the box.) Check out the manuals on the Roland site here
Feeding Dragon
Reply 6 of 10, by keropi
^ S-MPU's "intelligent mode" does not work reliably with DOS games.
One can read more here: http://nerdlypleasures.blogspot.gr/2010/03/tu … land-mt-32.html
Reply 7 of 10, by FeedingDragon
Since it's put out by Roland, I'm wondering why they didn't make it completely compatible? Or was it a case of breaking things while they were fixing them? Personally, I got a MPU-401AT and called it quits 😀 Got a SCC-55 on the card, a MT-32 (old model) on the desk, and have been keeping an eye out for a CM-32L. All-in-all, though, it's still "mostly" intelligent 😀 Just out of curiosity, what games does it have problems with?
Feeding Dragon
Reply 8 of 10, by keropi
When the S-MPU line was released "intelligent mode" was a thing of the past... plus it was meant for serious work so I believe noone cared about intelligent mode being picky/not_working on DOS. I've read many reports online about this thing and never really got one to test 😀
Don't worry about the 401AT , it's fully compatible , I got one running in my p1 dos machine and tested it extensively 😉
A couple of games to test intelligent mode are Gateway and Laser Squad, if music plays fine on them then the interface is ok.
Reply 9 of 10, by vetz
I have a S-MPU card on the way from Japan. I'm planning on using it in a Pentium Pro build I'm putting together. Since I love special touches in my systems I'm planning to use a ASUS MEDIA BUS card with SCSI and Vibra 16 (with OPL3 chip). The MIDI is totally broken on this card, so I needed another solution. I'll report back when I get it up and running with my findings 😀
I'm interested to see if I can run SOFTMPU on it. Then there will be no problems with intelligent mode as SoftMPU supports all those games.
Reply 10 of 10, by PeterLI
The S-MPU-AT is partially hardware intelligent: it relies on detection of intelligent MPU-401 requests to become MPU-IPC-T compatible (intelligent).
http://media.rolandus.com/manuals/S-MPU-AT_OM.pdf
The S-MPU-IIAT relies on a DOS TSR to become intelligent emulated.
http://media.rolandus.com/manuals/S-MPUII_OM.pdf
Both products were designed for Windows and not DOS back in the day.
I owned both but found the MPU-401, MPU-401AT, MPU-IPC, MPU-IPC-T, SCC-1 and LAPC-I to be better alternatives. As well as select clones such as the Midiman MM-401 and Music Quest PC MIDI Cards (8 & 16BIT).
The S-MPU-AT BOB pops up on eBay from time to time and is usually pretty cheap.
