First post, by Jeckidy
- Newbie
Hello, I'm new here and was given this site as a recommendation from the users at Sega-16.
I see that you can buy cheap USB 3.5 floppy drives on eBay with legacy support in mind. However, I want to know if the same is available for the 5.25 format? And if there is no modern USB devices available for this, to what extent can I use a non-USB drive for the 5.25 disks on a modern PC, running, say, Windows 7? And what cables, etc. will I need to perform this operation?
Also, if there are any concerns about the 3.5 USB drives available, let me know. Thanks!
