ripsaw8080 wrote:GOG uses DOSBox.
Have you tried joysticktype=auto and joysticktype=2axis in the .conf settings?
There should be some startup messages for joysticks in the status window, what do you see there?
Tried both "auto" and "2axis" and the keymapper still doesn't see the select, start, B, and A buttons.
I don't know what you mean by startup messages for joysticks. But I just hit Control and F1 to get into the Keymapper. Then click on the keys I want changed and hit "add", then try and select whatever button on my controller I want to substitute for the key on the keyboard. As Duke Nukem games only recognize keyboard keys. I do believe in the game it has a joystick controller option, but that didn't work for me for my NES controller. So instead tried changing it in the DOSBox Keymapper.
Forgot to mention I also tried my SNES controller as I also have a USB adapter for that from the same company as the NES USB adapter. That controller has extra buttons on it. And some of the buttons on that are recognized in DOSBox Keymapper, though it doesn't recognize the Y and B buttons which are the two buttons I'd want to have working.
It recognized the X and A buttons, but those buttons are further away and too awkward to use as my fire and jump buttons.
