First post, by guest
First off let me say that Dosbox is great. It works fine, most of the time. 😀
The problem I see is with LSL6. Most times when there seems to be WAV out, the sound is clipped (and sound almost like a chirp), or the game sort of freezes, just as the sound is about to play (the menu works, though).
[The easiest way to repro this is to get your rooe key and open you room door a few times in a row.]
I have tried the latest version of libsdl (1.2.7), which improved the situation somewhat, as the "freezes" occur a bit less.
My system specs:
P4 3.0GHz, Asus P4C-800E, 1GB RAM
nVidia 5900, SB Audigy 2
Win XP Pro SP1
Any help with this would be appreciated.
Thank you.
