First post, by FeedingDragon
- Oldbie
Wasn't sure how to categorize this. It isn't exactly a bug, it's just a little strange (to me at least.) I just got a USB floppy drive (well a couple of weeks ago,) so I could take the some of the disk images I made years ago of some of my collection and put them back on floppy for use in my new (can I call it new?) vintage system. Also, so I could continue archiving the disks I didn't get to before the floppy on my main system stopped working (haven't had a working internal floppy drive on my main system for about 10 years now.) I'll have to find, unpack, and set up my Kryoflux to get the 5.25" disks archived, but that's another subject.
Now, some of my images are 720k floppies, which isn't a problem as I actually have more 720k disks than I do 1.44M disks. The first disk I put in immediately popped a message up about it needing to be formatted (I found this strange as it didn't do it with my 1.44M disks, even the ones that were Amiga formatted.) So I try to format it, only to receive a message that windows cannot format that type of disk. No problem, grew up on DOS, open a DOS window and use the format command. Disk formats, WinImage writes the image, it works just fine.
Here is where things start to get a little different. That particular game had 1 720K disk and several 1.44M disks. There wasn't a problem. Only, the next game was all 720k disks. This time, when windows said "need to format" I just clicked cancel and went straight to a command prompt, only to be told that the device doesn't support that format. WinImage says the same thing. After messing around with it, I put that first disk back in, only to get the same responses about the already formatted disk. Several disks later, along with several re-boots, several removing and plugging the drive back in, I finally click ok to windows "this disk needs to be formatted" pop-up on inserting the disk. Of course, I get the windows can't format that type of disk message. Only now, the drive is formatting and writing 720k disks without issue.
So, it only works with 1.44M disks until I insert a disk and "try" to format in windows. After that it handles 720k disks without a problem until I use it on a 1.44M disk (which it handles without an issue.) At this point, it refuses to work with 720k disks again until I try to let windows format one. Etc....
So, anyone who has a USB floppy drive. Is this behavior normal?? Is there a faster way than waiting as windows tries over and over to do what it apparently isn't designed to do to switch the drive to 720k mode? Mainly just curious as I find this behavior a little odd.
**edit** Addendum - Something I forgot. WinImage will only write to the disk if I have just formatted it and haven't actually removed it from the drive. Once I've removed it and re-inserted it, WinImage will start saying that the drive doesn't support that format again. This is for writing or comparing, not for reading a new image. Found that out by accident when I removed a just written disk and had forgotten to verify it with "compare." Slipped it back in and hit compare only to get the "not supported" message. Tried a write later (formatted, ejected, inserted, open WinImage & click write,) and got the same message.
Feeding Dragon
