First post, by cdoublejj
are FPM and EDO interchangeable? or would that cause a fire? and or are they notched differently?
Reply 1 of 6, by GeorgeMan
More modern motherboards (socket 7, most socket 5, late socket 3) support both.
If you insert an EDO in a mobo that only supports FPM, it just won't boot. They both work at the same voltage, so nothing will be damaged.
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
Reply 2 of 6, by Stojke
I have a montherboard that supports both in the same socket. So you're good to go.
Reply 3 of 6, by cdoublejj
does it support both at the same time? My mobo has 8mb of onboad ram.
Reply 4 of 6, by Stojke
I don't know (I doubt it). Check the motherboard manual to be 100% sure.
Reply 5 of 6, by GeorgeMan
No, if inserted both types on a machine that supports both, they'll run as FPM.
